#1 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
What does the gear select damper do?
I'm almost done rebuilding my Frankenstein gearbox, and it occurred to me that I don't really understand what the damper on the gear select shaft does. I mean, I can piece together that it dampens something, but is it a NVH reduction device or does it actually do some work when changing gears? The Celica and Matrix gearboxes had them, but they were very different. I.e. one was somewhat-asymmetrical and the other was completely-asymmetrical, whereas the Yaris/xB has an almost-symmetrical damper.
If it's only there to provide resistance at the shifter--increased shift effort--then I may just run without it! |
Off of the tranny, what does that big ol' chunk of metal weigh?
#3 |
Just over 2 lbs.
#4 |
Ah, not as heavy as I thought. I suspect that its purpose is to dampen vibration through the cable to the shifter, and possibly to assist with shifting as the momentum of it would help with fully engaging a position. The shape is probably just based on what's around it once the tranny is mounted in the engine bay.
#5 |
That's what I was thinking, but it helps to have someone else articulate it. I'm not worried about NVH, but there's the issue of dust protection for that end of the shifter: the bellows isn't sealed by the damper, but it looks like it keeps it in place (more or less).
| Experimenting with bypassing the AT 4th gear prohibition when cold | CTScott | Performance Modifications | 28 | 03-22-2015 08:16 AM |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| 2006 Yaris 1.3 TR, 80k miles- Clutch need pressing to its end OR Gear change getshard | planet | DIY / Maintenance / Service | 0 | 08-15-2010 10:20 AM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| New Owner - Lights on Gear Shift | javagirl | New YARIS Purchase Forum | 8 | 05-22-2009 02:23 AM |
