Old 07-31-2014, 11:15 AM   #1
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Car occassionally makes brief squealing noise at startup...
Didn't start until I had the belt replaced about 25k miles ago. Happens in any weather... had one shop install it and squeal started. They told me sometimes it's caused by the belt stretching after new install or something of that nature. They tightened it and the noise went away for a while.
Started doing it again more recently so I had another shop look at it. They said it does it for like an instant at startup but they didn't hear anything else past that and I guess there wasn't anything they could do to fix it?
The second shop did suggest it might be a pully going bad? I guess the pulley's have bearings???
Anybody?
firebird1999us is offline   Reply With Quote
Old 07-31-2014, 11:32 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The belt has loosened again. Just retighten it
Old 07-31-2014, 02:18 PM   #3
What brand of belt is it? Some of the stiffer composition belts (like Dayco) are prone to that behavior.
Old 07-31-2014, 02:57 PM   #4
firebird1999us
Drives: 2003 Mach 1
I'm not 100% sure - but I will inquire when I'm in for my next service. The other shop I went to couldn't find any issues with the car at all so I'm guessing it's likely what you're describing...
Old 07-31-2014, 03:21 PM   #5
I ran into this with my red Yaris, when I installed a Dayco belt. I tightened it about half a dozen times before I threw it in the trash and installed a Gates.
Old 07-31-2014, 05:25 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I'm pretty sure it's the belt as well. Mine was just about to explode when I finally figured out where the sound came from.
Old 07-31-2014, 07:35 PM   #7
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Ive had this for a long time. I figured it was the aluminum MI pulley. I think the belt I installed was a Dayco...ill check when I get a moment
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-05-2014, 04:51 PM   #8
esse10
Drives: 2009 yaris 2 door
dayco ,
Correct it's the Dayco cheapo belt I have the same belt and same minor issue. Get the gates or the OEM Toyota.
Old 08-27-2014, 04:20 PM   #9
albee213
Drives: No longer own a Yaris
Belt squeel can be from a belt not tight enough, too tight, warn belt, a crappy new one or crooked warn pullys.
albee213 is offline   Reply With Quote
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 10:10 PM
car making cheap car noise the_boss Cosmetic Modifications (Exterior/Interior) 5 03-07-2011 08:05 AM
Who makes the best custom fit car cover for our car? YarisSedan General Yaris / Vitz Discussion 8 04-29-2009 11:13 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
