Old 07-31-2014, 11:19 AM   #1
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Getting wheels powder coated - need cliffnotes on best way to have car on stands...
....for 5-6 days while the wheels are getting done?
Any suggestions?
firebird1999us is offline   Reply With Quote
Old 07-31-2014, 11:31 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I personally don't feel comfortable leaving my car on weenie little jack stands for that long. I'd find some large pieces of wood or cinder block, pad them, and then lower the car onto them. They're much more stable than just jack stands.
Old 07-31-2014, 12:40 PM   #3
firebird1999us
Drives: 2003 Mach 1
Yeah that's what I was thinking - cinder blocks or like deck piers seem like a much more stable option. What would be the best placements for them under the car? I'll consult my manual when I get out to the car... just curious if there are any spots anyone would recommend?
Old 07-31-2014, 01:01 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The regular jack points will probably be the best since they're the widest apart without putting blocks under your shocks/springs
Old 07-31-2014, 02:05 PM   #5
You should not use cinder blocks, as they are not designed for the psi load of a vehicle and can fail. 4 jack stands at their lowest setting would be fine if the car is on a level surface. You can slide some blocks under the car as a backup for the stands, but the stands should be supporting the load.
Old 07-31-2014, 02:16 PM   #6
chapabig
3dr Angry Bubble
Drives: 07 Yaris HB
THIS
chapabig is offline   Reply With Quote
Old 07-31-2014, 03:03 PM   #7
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I usually place the 4 jack stands in these locations.
Your floor must be level.
Old 07-31-2014, 03:50 PM   #8
Rigaud
Drives: 2009 Yaris
Jack stands are made for that purpose if positioned in the proper resting points on the car. Also they need to have proper weight rating and let's face it, the car weighs 2400lbs and one jack stand the smallest usually hold 1 ton each. I have three snow cats up on jack stands at work, they weigh in stripped down summer mode at 4.5-5 tons. Their all on jack stands till October.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 07-31-2014, 04:14 PM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I know they're designed like that. But this guy and I have similar, probably paranoid, concerns about leaving a car on stands. Scott is right, cinder blocks aren't technically rated to hold a car.
That being said I'd be okay leaving my car on a 6 x 6 wood block for a few hours.
Old 07-31-2014, 07:01 PM   #10
firebird1999us
Drives: 2003 Mach 1
Tremendously helpful! Thanks!
Old 08-04-2014, 05:14 PM   #11
justjesus
justjesus's Avatar
Drives: 2008 Liftback
like scott said. Cinder blocks can fail.
My buddy used wood for a long time....until one finally split, causing quite a bit of damage.
I've had one of my cars on stands for a good month, maybe more.
Old 08-04-2014, 09:18 PM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
might sound silly but you have no way to get a hold of a set of wheels/tires to just slap on for the time needed?
Hey Yaris folks! Not a Yaris but Prius C here, lowered the car and wheels BoostTed Off-topic / Other Cars / Everything else Discussions 10 04-04-2015 09:00 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Black powder coat my wheels? vacantj Cosmetic Modifications (Exterior/Interior) 7 09-03-2007 01:56 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
