Old 07-31-2014, 08:46 PM   #1
MoneyT8
Drives: White Yaris Sedan
Does anyone have Yaris Automatic Transmission Shift issue?
Hi, my 2007 Yaris automatic shift just recently gave out meaning it doesn't shift anymore. I can't even shift into Drive to move the car; it feels almost as if the shifter is disconnected. Does anyone else have this exact same issue? What would be the fix? Is this a known issue with Yaris? Thanks.
MoneyT8 is offline   Reply With Quote
Old 07-31-2014, 08:55 PM   #2
I have not heard of that happening with a Yaris yet. Hopefully it is just a disconnected shifter cable. Does it seem to be stuck in park where it will not move at all (even pushing it in neutral)?
Old 07-31-2014, 09:02 PM   #3
MoneyT8
It's stuck in park mode and the car will not move despite moving the shifter into Drive/Reverse. I've heard the remedy was to replace the transmission, man that's expensive. I don't understand how this can happen. Thanks.
Old 07-31-2014, 09:57 PM   #4
Does the gear indicator on the cluster change when you move the shift lever?
The U340E Transmission in your Yaris coolcat21 DIY / Maintenance / Service 10 09-02-2014 10:15 PM
Automatic Transmission 4 Yaris Sedan 1.3 Girishk19 General Yaris / Vitz Discussion 10 06-28-2011 05:02 AM
yaris automatic or auto clutch ? webb UK 1 06-25-2011 03:20 PM
