Old 07-31-2014, 09:37 PM   #1
nortonfb
Drives: 2007
Valet 712t issue
I have installed the Valet 712t (thanks for the DIY & Dan & Scott).
The only issue I have is the horn doesn't work when the alarm is activated.
The horn does work with the panic button.
I do have an after market air horn with relay.
The weird thing is, with the door open and I try the alarm the door buzzer will work like the horn is supposed too.
Any thoughts?
Thanks,
Steve
nortonfb is offline   Reply With Quote
Old 07-31-2014, 09:59 PM   #2
If it works with the panic button then it sounds like a configuration issue with the 712. Go through the config menus for it and make sure that the alarm output is set to the horn and not to an external siren output.
Old 08-01-2014, 08:06 AM   #3
nortonfb
Drives: 2007
thanks Scott.
I will give it a try.
Steve
Old 08-01-2014, 07:02 PM   #4
nortonfb
Drives: 2007
Still having the same issue.
The instruction booklet states that "if in audible mode".
How do you get into audible mode?
I turned the valet portion on & off and pressed the aux button
which triggered the horn.
The horn will not activate with the locks.
Thanks,
Steve
Old 08-01-2014, 09:40 PM   #5
Thanks,
Steve
Sounds like a question for Valet. The DEI product instruction books always leave you scratching your head.
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
yaris voltage issue yaris2010RS DIY / Maintenance / Service 11 12-29-2012 04:20 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
Keyless question lita_g In Car Entertainment + Electronics (audio / video / alarm) 45 08-11-2009 11:13 AM
Valet 712t not working yaris prime In Car Entertainment + Electronics (audio / video / alarm) 2 04-23-2009 06:53 PM
