#1 |
![]() Drives: Yaris 2013 1.3 99 HP 6 speed Join Date: Feb 2014
Which engine oil is best for Yaris 3rd Gen?
Hi
Please ,I own Yaris 2013 third Generation,it s 1.3 vvti 99 bhp and I would like to know about the oil engine that Toyoyta specialist recommend for the car .I use 15w40 but I have a doubt that s not excellent thanks in advance |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
I would think that a synthetic 5w20 or even a zero weight.
. Steve |
#3 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
What does it say on the oil cap on the engine?
#4 |
Or the owners manual?
Synthetic Oil: Its All In Your Head |
#5 |
![]() ![]() Drives: 2014 Icon+ 1.33l Multidrive Join Date: Nov 2010
For U.K. models, same engine, 0W20(preferred)) or 5W30 to API SL, SM or SN. It's not marked on the oil filler cap on my car. However, as you are in Algeria where it will definitely be much hotter a different, higher viscocity could well be recommended. My handbook states that both the viscocities above are fine for temperatures ranging -29 deg.C to 38 deg.C but the arrows indicate lower and higher than those temperatures.
What does it say in the owner's manual? Why don't you 'phone a Toyota dealer and ask them what they use/recommend? |
#6 |
The car is still under warranty and usually I maintain my car in Toyota garage here in Algiers .they use the 15w40 on every oil change .in the manuel there are some explanation but I m not sure and I could not understand technical info ,that why I m looking for your advice lol
that s true the weather in Algeria is hotter than other European or american countries which involve special oil engine the thing is that I doudt about Toyota agent using Total 15w40.I have heard and checked some websites that 5w30 is better ;improve fuel efficiency and car performance |
#7 | |
Well, you might not properly protect your engine with harsh temps like in Algeria if you go with 5w30. 5w30 is what is normally used in North America. |
#8 | |
I doubt use the thicker oil will have an adverse impact on the engine. Offhand I would say it makes sense.
#9 |
![]() Drives: 2014 Yaris Icon + 1.4D4D Join Date: Mar 2010
Toyota list the following as acceptable for 1NR 1.33 Yaris:
20W-50 and 15W-40 API grade SL, SM multigrade engine oil 10W-30, 5W-30, 5W-20 and 0W-20 API grade SL "energy-conserving", SM "energy-conserving",or ILSAC* multigrade engine oil |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Used Oil Analysis : 2010 3 door Yaris : 4,341 mis. on oil and 16,611 miles on engine | Hershey | DIY / Maintenance / Service | 22 | 08-04-2011 10:52 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Dealership filled engine with too much oil... | posaunemeister | DIY / Maintenance / Service | 17 | 10-18-2009 11:21 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
