Old 08-06-2014, 09:02 AM   #1
johnbry
Drives: yaris
clutch change
2007 yaris manual transmission
how much time does it take to change a manual transmission clutch?
are any special tools required?
I have about 75,000miles. i feel it slipping slightly maybe when its wet.
how does it fail? does it simply slip and fail to grab?
do bad things happen if i wait too long?
at what mileage should I change the timing belt?
thanks for help
johnbry is offline   Reply With Quote
Old 08-06-2014, 10:55 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
There is no timing belt. The 1nz utilizes a timing chain and not a belt.
Timing chains are built for the life of the car however while they can technically last longer, it is suggested that you change it at 200k.
Old 08-06-2014, 10:58 AM   #3
fnkngrv
fnkngrv's Avatar
The clutch swap shouldn't take more than a couple hours with a lift and tranny jack. I've dropped the clutch without dropping the engine, but it's almost easier to pull the whole engine and do the clutch on a bench, but that's my opinion of course. If you don't have a lift and you are a DIY sort of person then you are looking at 3-4 hours. If you haven't ever done it then double that for allowed time to be safe.
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
clutch change interval goofy gorilla DIY / Maintenance / Service 5 10-11-2011 08:46 PM
2006 Yaris 1.3 TR, 80k miles- Clutch need pressing to its end OR Gear change getshard planet DIY / Maintenance / Service 0 08-15-2010 10:20 AM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
