Old 08-10-2014, 08:52 AM   #1
driverofchuckles
driverofchuckles's Avatar
Drives: 2008 Yaris. Manual everything
cigarette lighter power port
In my first car, 93 Tercel most basic model available, I made the cigarette lighter power port "Always On". I want to do the same in my 08 3 door HB but I cannot, for the life of me, remember how I did it! I've scoured the forum but my searching has been unable to find anything. Any help, advice, or suggestions for this will be greatly appreciated!
driverofchuckles is offline   Reply With Quote
Old 08-10-2014, 09:30 AM   #2
The power outlet on the Yaris is acc switched along with quite a few other things. The easiest way to change it would be to clip the +12 wire to it (the grey wire) and feed it from a non switched source. The easiest way to do that is to use the constant 12 volt connection shown in my remote start DIY (link below). You will also want to add an inline fuse between that terminal and the outlet.
http://www.yarisworld.com/forums/showthread.php?t=24860
Old 08-10-2014, 09:40 AM   #3
driverofchuckles
Thank you! You're description awakened the memories of when I've done this before. I will, however, go with your method. It is much better than what I did.
Cigarette Lighter Fuse tommy420 DIY / Maintenance / Service 2 02-12-2014 11:24 PM
Hole beneath cigarette lighter socket? dj92 In Car Entertainment + Electronics (audio / video / alarm) 1 02-06-2014 10:28 PM
