#1 |
Help Wifes Camry Not Running Right
It would not start last night so we had AAA jump it and it ran fine going home.
This morning it would not start again so I put in a new battery. Started and ran fine. But going to work it shut off. Wife turned off the radio and AC and the car made it to work ten miles away OK. No CEL. What could it be? Thanks!
Synthetic Oil: Its All In Your Head |
Sounds like the alternator is not working.
Check the large fusible links on the positive battery terminal to see if the alternator fuse popped, before looking for a new alternator.
#3 |
Ok thanks!
Is there any quick and dirty way to test the alternator?
#4 |
Wait I know one. Shine the lights on a wall at nite and rev the engine. If the lights dont get brighter its the alternator.
Right?
#5 | |
![]() ![]() Drives: 2007 Toyota Yaris LB Join Date: Mar 2007
https://www.youtube.com/watch?v=dq24oPUVmdA |
#6 |
Well well well wait til you hear THIS!
My wifes brother is a BMW mechanic. He looked at the car at my wifes work and drove it all around. No problem! He checked the alternator with a VOM. Normal. He thinks what happened is the computer took time to re set/reboot. Even though the new battery was good and the alternator worked properly, the computer remembered the sub par voltage and shut the car down. It took a while for the computer to recognize the new battery. Hows that grab you!
#7 | |
Not likely. Better keep the AAA number handy.
#8 |
Maybe.
This is the third battery. The first one we replaced this didn't happen. Stay tuned.
#9 |
Do alternators go bad intermittently?
#10 |
Did the headlite test Yaris and Camry nose to nose on a dark night street.
Neither car revving the engine did the headlites get brighter. Both cars engine at idle 14.5 volts. Turn on the AC both cars voltage drops to 14. Camry runs good no engine shutdown.
#11 |
Not usually. Typically they stop working completely or get very weak. If the voltage regulator within the alternator fails, you may see high voltages (18+ volts).
#12 |
I think we're good!
#13 |
Dont wanna sound like a prick... but sounds like you got a loose terminal. Ive seen that alot lately at the shop. Not the that there floppy loose but under engine vibration and such they wiggle around amd u dont get a good connection. I had that issue with my yukon when I put a battery in it I didnt get the positive to sit just so. Took me a while to find it too lol. Just a thought.
#14 | |
#15 | |
| Wheels On The Wifes 2005 Camry... | bronsin | Off-topic / Other Cars / Everything else Discussions | 5 | 04-27-2014 10:52 PM |
| 2015 Toyota Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 9 | 04-18-2014 06:47 PM |
| sunroof problem on my wife's 1997 Camry | slothman86 | Off-topic / Other Cars / Everything else Discussions | 1 | 06-07-2009 02:28 PM |
