Old 08-14-2014, 03:43 AM   #1
sWEat
Newbie
Drives: Suzuki SV650 2009
Toyota Yaris oil reccomendations?
Would like advice from a Toyota engineer on engine oil for a 2004 Yaris, have been told that it should be a fully synthetic oil, however I used to run my Corolla that I have recently traded in on a part synthetic 10/40, it was trouble free all the years that I owned it. Any advice would be appreciated.
sWEat is offline   Reply With Quote
Old 08-14-2014, 07:07 AM   #2
Dino oil is all fine in 5w30 for use in North America.
Old 03-30-2015, 08:19 AM   #3
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
Just switched to full synthetic, kept same 5w30. It's amazing. My engine is so quiet, it's even more so than the day I bought it!
Overall I'm happy with the change. Just need to keep my eye on if there is any burn.
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 03-30-2015, 12:32 PM   #4
nortonfb
Drives: 2007
I have been using Total (Elf) 5/30 full synthetic with a Denso filter.
No complaints. In my last Yaris I used Mobil 1 extended. I switched to the
Total because it's cheaper.
Never had a problem with either.
Norton
nortonfb is offline   Reply With Quote
Old 03-30-2015, 01:34 PM   #5
Jcp123
Drives: '00 Echo
I'm running Mobil1 Advanced Fuel Economy 0w30 synthetic right now. Car seems to like it just fine. I have one more jug then I switch to Pennzoil Ultra Platinum 5w30. I am intrigued by the really pure base stocks for the Pennzoil, derived from natural gas. Mobil1 and Pennzoil Ultra probably are the two best oils on the market.
Having said that, any ol oil should work in the car. Ran a smorgasbord of Dino 10w40s for a while.
Pair whatever you get with a good filter. Wix, Fram Ultra, Purolator PureOne. Or Bosch Distance Plus, which is a rebranded PureOne.
Jcp123 is offline   Reply With Quote
Old 03-30-2015, 03:09 PM   #6
Septembersrain
♣♀Yaris'ing♀♣
I'm running Mobil1 too, using a TRD filter though.
Old 03-30-2015, 08:12 PM   #7
0w30 Amsoil signature series and Amsoil EK filter here.
First year with the 0w30, it does provide better cold start in the winter.
Old 03-31-2015, 07:10 AM   #8
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Does the 0w30 get you a better mileage?
I'm using 5w30 and thinking about using the recommended 0w20 on the next change.
I drive, therefore I am.
Old 03-31-2015, 07:32 AM   #9
Jcp123
Drives: '00 Echo
Technically, I guess 0w30 gives a smidge better mileage, esp in winter...but it's statistically insignificant.
Not sure I'd be brave enough to try 5w20 or 0w20 in one of these...
Old 03-31-2015, 08:27 AM   #10
bronsin
bronsin's Avatar
The medical courier whose Yaris has 500k on it uses Walmart Synthetic.
5-30.
Old 03-31-2015, 05:21 PM   #11
No. 0w30 still have the same viscosity at full operating temps. It simply gives easier start up as it is less viscous at cold temps.
