Old 08-14-2014, 08:37 AM   #1
fishlurcher
Drives: Toyota Yaris 2003 1.0 vvti
EP Steering problem
Hi all, ok my 2003 Yaris 1.0 VVTi 3 door Colour collection has a steering problem, tracking was checked and fine, the steering will not centralise from turning left, turn right and all is fine, also feels weird when driving kinda wandering, everything stripped and checked to ensure free, ie track rod ends, hubs and struts free, EPS Light is NOT on, but checked it lights up and goes out after starting, so a change of Rack was next, Didn't make any difference, Steering has been zero'd, according to mechanic, any ideas please, don't want to change power column unless that's all it could be now
fishlurcher is offline   Reply With Quote
Old 08-14-2014, 09:29 AM   #2
Has the power steering motor assembly been changed? It has the torque sensors built into it for determining what the user is trying to do with the steering wheel.
As a side note, I was very surprised to see that your MK1 Yaris has EPS. Our MK1 over here had hydraulic power steering.
Old 08-18-2014, 07:08 AM   #3
fishlurcher
Power steering motor is the one that was on it when purchased, I purchased from auction and fault was existing, so I have not had it changed, mechanic has told me he has calibrated steering when replacement rack was fitted, as steering seems ok when turning right he is not convinced its the Electric power steering motor in response to side note would have preferred it to have hydraulic PS
Old 08-18-2014, 09:44 AM   #4
Try pulling the EPS fuse in in the under bonnet fuse panel and see if it feels fine (other than without the assist you will get a bit of a workout when turning the wheel at low speed).
Old 08-23-2014, 11:06 AM   #5
fishlurcher
Thank you CT Scott will try that sorry big gaps in progress with this just my work keeps me away for days, will try that tomorrow and let you know asap how I get on
Old 08-25-2014, 01:24 PM   #6
fishlurcher
Pulled 50 amp fuse that said EMPS, Must be right one as no PS red PS Light on dash also, sadly still seems the same, not centralising completely when turning left
Old 08-25-2014, 01:49 PM   #7
OK. In that case, your problem is definitely below the steering column. Besides the rack itself, it could be a suspension or tire issue.
Old 08-26-2014, 06:23 AM   #8
fishlurcher
Thanks again, Is the castor/camber adjustable on these or is it fixed ? could it be this ? I am starting to think the garage is a bit suspect, will get tracking checked elsewhere again
Old 08-26-2014, 06:43 AM   #9
The caster and camber have a very small amount of adjustment. Has the shop that adjusted your tracking (what we term alignment) given you a printout that shows the before and after of the adjustments that they made?
Old 08-26-2014, 08:08 AM   #10
I've had similar issue when i had an accident with my gen1. I hit a curb, sorta.
The steering rack was the culprit, where the steering wheel would not come back when i turn to a complete left. I had to have the steering rack rebuilt.
Old 08-27-2014, 07:46 AM   #11
fishlurcher
No I am going to have Tracking/alignment checked again ffs I have lost faith in that garage
Old 08-27-2014, 07:49 AM   #12
fishlurcher
Had replacement rack which although 2nd hand was a good one, seems to be nowt wrong with original now
Old 12-23-2014, 05:06 PM   #13
Astroman
Modded Moderator
Astroman's Avatar
This was posted in the wrong section, moved it. Please remember to post your threads in the correct section.
steering issues
Electric power steering Geoff Peace DIY / Maintenance / Service 4 04-10-2018 05:28 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Yaris TR 1.3 '08 AC problem Eeman DIY / Maintenance / Service 5 07-03-2014 04:59 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
