Old 08-14-2014, 11:53 AM   #1
Foxy
Drives: vitz 2000
Smile engine light on
My engine light is on after a few minutes driving. I had it serviced which included oil change, oil filter and air filter changed a month ago. Can anyone help please?
Hey I just noticed also that the engine light warning comes on when I have the air conditioner on. Any help please?
Foxy is offline   Reply With Quote
Old 08-14-2014, 12:25 PM   #2
You will have to get the CEL code so we can help. Otherwise, I would say bring it back to the garage so they can diagnose.
Old 08-24-2014, 03:18 PM   #3
aryan
aryan's Avatar
Drives: Vitz 2005
Showing check engine light for few minutes during drive and then invisible.
And in scanner getting below code
P0841 tranmission fluid pressure sensor/ switch 'A' range/performance
Anybody help me whats an actual problem ?
aryan is offline   Reply With Quote
Old 08-24-2014, 03:31 PM   #4
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Looks like overheating. Need to check cooling fluid, radiator, thermostat, and cooling fan.
jack black is offline   Reply With Quote
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Engine light Tintin2 DIY / Maintenance / Service 4 04-30-2014 04:58 AM
2012 Yaris LE Check Engine Light On/Eco Light Off 2012YarisLE DIY / Maintenance / Service 1 01-22-2014 11:29 AM
Engine light came on but seems to run fine naossoan DIY / Maintenance / Service 7 06-10-2013 04:51 PM
check engine light, engine turns but not start willygoodness DIY / Maintenance / Service 10 07-23-2012 05:10 PM
