Old 08-16-2014, 11:47 AM   #1
JDM::RSTLESS
Drives: Yaris 5dr hatchback 2nd gen
2SZ-FE custom air intake check engine light
Hi guys! I need some advise. So i got a air intake custom made which isnt fitted yet as i kept getting the check engine light come on. A hole is cut for the sensor but keeps get the CEI. When fitting the stock airbox, no engine light comes on. Any ideas? Below are some photos. Cheers!
JDM::RSTLESS is offline   Reply With Quote
Old 08-16-2014, 12:44 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
in the second pic it looks like the sensor is sitting sideways so air flow maybe not direct.
Old 08-16-2014, 01:00 PM   #3
JDM::RSTLESS
Thanks , the sensor is the same position as it was on the stock air filter box
Old 08-16-2014, 09:30 PM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Also, the diameter of the pipe needs to be the same as the OEM. If the diameter is larger, it affects the airflow value the sensor is picking up. I can't tell in the picture, but if the relocation of the sensor doesn't work, it may be the diameter of the pipe
-Derrick-
Old 08-16-2014, 09:31 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Hmmm never had that problem could be ...my intake is larger than stock made out of 3 I had around lol
sent from my S4 on Mars
Old 08-17-2014, 06:48 AM   #6
JDM::RSTLESS
Just had a look at the original position of the MAF on the stock air box and its downwards compared to the pic above. May be the issue but if that doesnt work, any other suggestions?
Thanks for suggestions so far guys!
Old 08-17-2014, 10:41 AM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
What is the diagnostics code? It's much easier to pinpoint with those than just a general "check engine" light.
Old 08-17-2014, 11:27 AM   #8
JDM::RSTLESS
Sorry mate, how do u get the code?
Old 08-17-2014, 11:42 AM   #9
CrankyOldMan
I'm not sure if there are car parts stores in the UK, but over here in the colonies we have stores that will read the codes with an OBD II scan tool for free. If not, a repair garage should be able to.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Check Engine Light on at 32k kilometers? caper26 DIY / Maintenance / Service 21 10-16-2013 12:27 PM
check engine light - reading codes? delbo21 DIY / Maintenance / Service 3 09-02-2011 05:48 AM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
