Old 08-18-2014, 10:34 PM   #1
Brhatcher
Drives: 2008 Yaris Hatchback
DIY Cruise Problem
I did the DIY Cruise on my 07 yaris 5 speed about a year ago.. Worked great for a couple months. Now when I pull out of the garage in the morning for my 81 mile commute the cruise works (usually all the way to work) the next morning (I work 24 hour shifts) when I get in the car it may or may not work... If it does work it probably won't within 30-40 mins. Seems to be heat related- ie- when the motor gets hot it doesn't work. I've checked my connections and everything is soldered. Anybody seen this before or have any ideas? This really sucks when I make the monthly 4 hour drives to the beach, which is the main reason I wanted it..
Brhatcher is offline   Reply With Quote
Old 08-18-2014, 10:51 PM   #2
Did you do the switch method or the OEM stalk method? Also, is the ECM pin an OEM one with the rubber seal?
Old 08-20-2014, 05:07 PM   #3
Brhatcher
I did the radio shack push buttons method mounted them in the little pop out beside the dimmer. No I did not use an oem ECM pin with rubber seal which of course leads me to believe that's probably the problem....
Old 08-20-2014, 05:09 PM   #4
Brhatcher
When I left work this morning it worked for about 20 mins then cruise suddenly shut off (which it normally just won't re-engage after I brake)
Old 08-20-2014, 05:39 PM   #5
I would check the ECM connection. It has likely gotten moisture in it. I sell the ECM pin alone for $5, if you want a real, sealed one.
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Yaris Cruise Control Auto evarkey Performance Modifications 1 07-02-2014 07:56 AM
2009 Toyota Yaris OEM Cruise Control DIY BentSpace DIY / Maintenance / Service 7 04-16-2014 09:05 PM
Cruise Control on 2010 Canadian Manual Kaya B. DIY / Maintenance / Service 25 10-01-2010 03:31 PM
Please post a picture of a DIY cruise stalk with the horn-to-cruise wire installed firemachine69 DIY / Maintenance / Service 18 09-29-2010 09:54 PM
