Old 04-22-2007, 04:12 PM   #1
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Attention NUTZOIDS : Picture's Requested
Didn't have your email to send direct, so here goes.
Anyone else who purchased the 15" full face hub caps, this is good practice before installing them.
They will pop right on very easy out of the box, the problem is they will pop off just as easy with the first pot hole you hit!
Before installing mine, I simply bent out each "tab" on the backside, just slightly.. you can also do this using the palm of your hand. VERY LITTLE pressure is needed to do this.
Once done, you will not or should not be able to remove them by hand.. you will kill your finger tips trying to pry them off the wheel!
For this reason, you will need to carry a paint can opener inside your car. This way in the event of a flat tire, you will be able to remove the hub cab, to then remove the wheel.
Enjoy.
Old 04-22-2007, 04:51 PM   #2
Vervepipes
CowCountry Hornet Handler
Vervepipes's Avatar
Drives: '08 Sedan
Dude! you need to oil your tools! Good info, I'm considering these in red for my '89 Hardbody "rat rod" project
Vervepipes is offline   Reply With Quote
Old 04-22-2007, 04:57 PM   #3
ChinoCharles
Drives: LB
I just took a rubber mallet to the insides of the tabs. I usually take the more abrasive way out.
Mine came off for paint. Stay tuned, tomorrow is going to be a good day.
Old 04-22-2007, 05:51 PM   #4
Chris07LB
Chris07LB's Avatar
Tools are fine.. that was one from a cheapie set.
Old 04-22-2007, 06:42 PM   #5
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Thanks Man...
Being scared Shitless once was good enough for me!
*Philosophy of life... Brought to you by... "Nutzoids"
Nutzoids... Where Punk rock is less about Image, and more about the Mind!
Nutzoids is offline   Reply With Quote
Old 04-23-2007, 11:47 AM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
dammm that tool is rusty....
Old 04-23-2007, 05:53 PM   #7
Chris07LB
Chris07LB's Avatar
Thank you.
Old 05-08-2007, 04:07 PM   #8
aephilli
Drives: 2007 yaris hatchback
where do i get these caps??
aephilli is offline   Reply With Quote
Old 05-08-2007, 04:11 PM   #9
Nutzoids
Nutzoids's Avatar
http://www.yarisworld.com/forums/sho...ight=Photoshop
There is a Link in this Thread
Old 05-08-2007, 04:18 PM   #10
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
i have some problems with them caps lately, they making some kind of weird noises while i'm driving.
Old 05-08-2007, 05:13 PM   #11
Nutzoids
Nutzoids's Avatar
hahaha... Me too...
It's like a clicking sound... I just pretend it's a go cart!
Old 05-08-2007, 05:40 PM   #12
jamal1984
Originally Posted by Nutzoids View Post
hahaha... Me too...
Man alot of peoples look at my car weird when i'm driving slow like 2-5 miles/hour, and them wheels keep making noisess. I have to find a way to fix it.
It's fun like hell when i roll all my windows down and listen to them sounds.
Power upgrade (pictures). W.A.S.P DIY / Maintenance / Service 91 11-15-2017 10:32 PM
