Old 08-19-2014, 07:12 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
OK how odd is this !!??wtf! ?
Upper strut mounts when parked on uneven road seem like they are up for some reason even now on even ground as if its floating ...wtf , nothing loose sitting on teins s tech drives normal .
sent from my S4 on Mars
Old 08-19-2014, 07:17 PM   #2
OMG! Not another floating top hat thread, and you work for Toyota.
This got pounded to death a few years back.
Old 08-19-2014, 07:19 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Lol I know ...and first time I ever so it lol not like Toyota has classes about floating top hat ..my question ...it's normal I would say or what lol
Old 08-19-2014, 07:26 PM   #4
Yes, normal. If you observe the top hat position with steering dead center, and then observe them at full left and full right, you will notice that they change in relation to steering. My guess is that the struts require a floating rather than rigid mount.
There was a time when people would post 'WTF did I do?' threads after changing their springs. The floating top hat is observed post install when checking to make sure everything is tight and right. Nobody ever happens to observe the top hat position pre-install. Those that could 'swear' the top hat sat tight to the strut tower before swapping springs, happened to have made that observation while the car was raised.
Old 08-19-2014, 07:28 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Good point I only see that area when car on hoist I noticed it now cos I was moving some cables around at home and had a look while she sits on all four lol
Old 08-19-2014, 07:34 PM   #6
This http://www.yarisworld.com/forums/showthread.php?t=32397 is one of my favourite threads on the subject. Read it through for a good chuckle.
And another one that's kind of fun http://www.yarisworld.com/forums/showthread.php?t=34230
Old 08-19-2014, 07:39 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Lol ...good one and 100% clear on floating top hats 😝 tx for the link :)
Old 09-15-2014, 08:37 PM   #8
sheekeebut
Minimalist
Drives: 07 silver sedan
Well this clears things up nicely. Now I can start looking at strut tower braces again. The ones that hook up to the body, of course.
And to help disseminate this knowledge to the rest of the 'net:
The floating strut top washer is designed to allow proper rotation of the strut assembly at the strut bearing during steering. If the nut were somehow tightened more, the washer would be pushed more tightly against the strut tower, becoming a major point of friction and defeating the purpose of the strut bearing (in this design).
sheekeebut is offline   Reply With Quote
Old 09-15-2014, 08:39 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Hmmm, why they will have no effect on our cars
Old 09-15-2014, 08:51 PM   #10
sheekeebut
Minimalist
I think it's about the body deformation at the towers on suspension movement. I don't know what benefits there may be for rebound, but at compression, a properly chosen brace should give that rigidity once the rubber mount has compressed all it's got.
Only one way to find out :)
And if there really is no difference, at least I have a sexy and mildly expensive conversation piece.
Old 09-15-2014, 08:55 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Ull have a sexy and expensive conversation piece ...the strut is not directly connected to the car only by rubber
Old 09-15-2014, 09:22 PM   #12
sheekeebut
Minimalist
From the looks of the assembly and installation instructions for OEM and Tein coilovers, it looks like the only thing in direct contact with the strut tower (hole) is the rubber upper strut mount and the (rubbery) top washer, like a rubber sandwich...
Gross...
Old 09-15-2014, 09:23 PM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Lmao ...yup
Old 09-15-2014, 09:25 PM   #14
sheekeebut
Minimalist
And not even a nice tight sandwich, but a loose, economical sandwich that needs the weight of the metal slice of ham in between to hold it down.
Old 09-15-2014, 09:27 PM   #15
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Its an odd design I don't like it but it works
Old 09-15-2014, 09:29 PM   #16
sheekeebut
Minimalist
While the threaded toothpick with the M12 nylock olive keep the top slice of bread flapping above everything, making it look badly installed and unappetizing.
Old 09-15-2014, 09:57 PM   #17
sheekeebut
Minimalist
Actually, if I wanted the right analogy, that little olive just keeps the toothpick from sliding out from under this pathetic sandwich.
Odd throttle issue mr_miles DIY / Maintenance / Service 21 11-01-2014 09:20 AM
Odd pop from front driver wheel area. hades12 DIY / Maintenance / Service 5 10-10-2011 12:12 PM
An odd first gear. Evangelion335 General Yaris / Vitz Discussion 13 03-19-2011 11:08 AM
Odd sound, 2008 Sedan MUSKOKA800 General Yaris / Vitz Discussion 12 11-05-2010 04:20 PM
Odd that noone has posted this yet... H3LlIoN Fuel Economy Forum 36 11-25-2009 11:07 PM
