Old 08-24-2014, 03:25 AM   #1
Trærup
Drives: Yaris 1.4 D4D 2007
Lowest springs
Hey guys.
I have a yaris 2007 5 door HB. Which springs are the lowest and Best? Tein?
Michael :-)
Trærup is offline   Reply With Quote
Old 08-24-2014, 04:12 AM   #2
Springs only. Lowest is probably tein.
Can't say for the best springs as lowest is not always the best.
Old 08-24-2014, 04:16 AM   #3
Trærup
I Know' :-)
- what about tanabe's?
Old 08-24-2014, 06:35 AM   #4
Astroman
Modded Moderator
Astroman's Avatar
Lower than tein, Sprint Performance. Mine lowered 2 inches.
Old 08-24-2014, 06:36 AM   #5
Trærup
And where do you buy Them?
Old 08-24-2014, 06:44 AM   #6
Astroman
Modded Moderator
Astroman's Avatar
http://www.sportcompactonly.com/Toyo...0934_v-224.htm
It says a 1.75" drop, but mine dropped 2 inches, and others have said the same. Great springs been using mine almost 7 years.
Old 08-24-2014, 07:03 AM   #7
Trærup
Okay thanks. Which struts should i go for?
Old 08-24-2014, 09:08 AM   #8
If you are looking for maximum drop, do go with coilovers.
Old 08-24-2014, 09:10 AM   #9
Trærup
I search for max drop on springs! I Wont drive with coilovers in the Winther :-)
Old 08-24-2014, 09:45 AM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Coilovers and winter don't mix ...I'm on tein's and its a nice drop don't know if I would go any lower with the snow we get up here , I do recommend u spray them with underbody rust paint cos my last set of sportline springs got eaten by rust over 2 winters
sent from my S4 on Mars
Old 08-24-2014, 09:48 AM   #11
Trærup
Which tein's do you drive with and do you have a pic of your car in lowed mode?
Old 08-24-2014, 09:50 AM   #12
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I have tein s tech and I would say around 2 inch drop
Old 08-24-2014, 09:51 AM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I'm on 195 55 15s....as for struts I use KYB's
Old 08-24-2014, 09:55 AM   #14
Trærup
Looks great! I Think i go for tein
Old 08-24-2014, 09:56 AM   #15
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
It's a good set up over all ..and tx
Old 08-24-2014, 10:00 AM   #16
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Also keep in mind my Yaris is base and 3 door with a 5 door u have little more weight so it should sit lower just a bit
Old 08-24-2014, 10:01 AM   #17
Trærup
Mine is a 5D. I dont Think there is much weight different?
Old 08-24-2014, 07:44 PM   #18
Astroman
Modded Moderator
Astroman's Avatar
The TEIN sit higher than the sprint springs, you actually have wheel gap there. Sprint settled 2", more than the TEIN and the OP was asking about the lowest springs.
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Lowest drop available with springs hatchbackkid82 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-14-2008 03:09 PM
Lowest Drop On Springs? Kaeon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 08-20-2007 04:15 PM
