Old 08-30-2014, 01:31 AM   #1
syxt3
Drives: Rolf Yarris
Yaris lower engine noise- any ideas?
Hi all,
lower engine noise- or loose timing chain?
130,000 KM got a new water pump fitted, picked the car up end of business on Friday and 20 minutes later this noise started.
Drove home and taking it back in to the shop Monday.
check the video and any/all comments welcome.
https://www.youtube.com/watch?v=jFlL...be&safe=active
cheers
syxt3 is offline   Reply With Quote
Old 08-30-2014, 04:37 PM   #2
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Hard to tell from the quality of sound recording.
Maybe defective water pump or mechanics screwed it up?
jack black is offline   Reply With Quote
Old 08-30-2014, 10:01 PM   #3
clarenceie
Drives: Yaris Sedan
I'm going for water pump also. My guess for the early failure will be the belt was put on too tight. This happened to me before, but with another car.
clarenceie is offline   Reply With Quote
Old 08-30-2014, 10:10 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Sounds like water pump ...remove belt see if u can feel play in water pump pully and any leaks or dry coolant ...to me sounds like the bearing let go , they make nose first then leak or explode lol
sent from my S4 on Mars
Old 08-31-2014, 04:45 PM   #5
sheekeebut
Minimalist
Drives: 07 silver sedan
Does it make a ticking noise at every other engine revolution (~4 ticks per second at around 600 rpm), and only on idle?
If so, you've got the same problem as me.
sheekeebut is offline   Reply With Quote
Old 08-31-2014, 05:10 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Originally Posted by sheekeebut View Post
Does it make a ticking noise at every half engine revolution (~4 ticks per second at around 600 rpm), and only on idle?
That sounds normal ...mine does it too ,they all do it lol
The sound in vid sounds to me like a water pump bearing on its way out .
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
Noise from rear of Yaris APS67 DIY / Maintenance / Service 5 09-25-2011 06:51 AM
