Old 09-01-2014, 04:58 PM   #1
MoneyT8
Drives: White Yaris Sedan
Why won''t my airbag light go away?
Hello, my airbig lights won't go away when I turn on my engine. I would like to clear these lights or fix them but don't know how. I've been thinking about taking it to a dealership but they probably want an arm and a leg just to look at it. I'm worried about my safety if these airbags are damaged or won't deploy in an accident.
What can I do? Thanks in advance.
MoneyT8 is offline   Reply With Quote
Old 09-01-2014, 06:09 PM   #2
Most likely your spiral cable is the issue and most 2nd generation Yaris are under the recall for said issue. If you want to be sure before knocking on the dealer's door, you can read the codes yourself with just jumping two pins on the OBD port under the dash:
http://www.yarisworld.com/forums/sho...d=1#post557473
SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! tylerwatts53 DIY / Maintenance / Service 1 07-17-2014 08:53 AM
Fan Not Spinning Up, Random Airbag Light drannonb DIY / Maintenance / Service 12 10-23-2012 03:33 PM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
