Old 09-05-2014, 07:37 PM   #1
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Cool Yaris S gauge cluster install in my 2009!
Took 10 minutes max and works like a charm!
firebird1999us is offline   Reply With Quote
Old 09-05-2014, 09:39 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Did you have the odometer matched? I swapped mine out but didn't bother since MI only requires you to note the existence of the discrepancy, not the difference.
Old 09-05-2014, 10:48 PM   #3
I matched the odo for him.
Old 09-05-2014, 11:58 PM   #4
axiom
axiom's Avatar
Drives: 2007 Yaris
Man! How do I get one of these?
axiom is offline   Reply With Quote
Old 09-06-2014, 12:36 AM   #5
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Forgive my ignorance, but how is the "Yaris S gauge cluster" different from the base gauge cluster? Tachometer?
Kalispel is offline   Reply With Quote
Old 09-06-2014, 01:26 AM   #6
bladesmith6
Drives: 2007 yaris HB
ctscott is the bomb! i had him switch the leds to blue and match the odo reading, love my cluster.
bladesmith6 is offline   Reply With Quote
Old 09-06-2014, 07:34 AM   #7
For the US market, prior to 2010 only "S" Yaris had the tach.
Old 09-06-2014, 08:50 AM   #8
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Wow I haven't seen a S cluster in a long time, you , I and few others have these and not the Canadian ones.
Now I'm still hoping for a digital LHD one
Check out my Build thread:
Old 09-06-2014, 08:56 AM   #9
firebird1999us
Drives: 2003 Mach 1
Big thanks to CTscott for programming the correct mileage and shipping it down here for me! I know it's more less just a cosmetic mod but I missed not having a tach and didn't want to do a non-matching aftermarket piece. Install was really a piece of cake!
Old 09-06-2014, 10:03 AM   #10
axiom
axiom's Avatar
Drives: 2007 Yaris
Seriously, how'd you get it? I would love to get one. Thanks!
Old 09-06-2014, 12:49 PM   #11
Kar98
Drives: 2011 Scion tC
I forgot, is there such a thing as instrument cluster for a manual Yaris 2, with tach?
Old 09-06-2014, 12:53 PM   #12
I had picked that one up from a local junkyard quite a while ago. The S ones are very hard to find, as there are not many of them around, let alone wrecked.
I can also convert Canadian ones to have he odometer increment in miles and have the outer ring of the speedometer indicate mph, rather than km/h. The Canadian ones are way easier to find, as tachs were not just for S models up there.
Old 09-06-2014, 09:28 PM   #13
ezhacker1
ezhacker1's Avatar
Yeah its pretty rare to see any S yaris. Came down to luck for me to snatch it off of the forums.
Old 09-06-2014, 09:56 PM   #14
Only 2010+ for the US.
Old 09-20-2014, 07:22 AM   #15
beaker
Drives: 07 Yaris 3 door
I have an 07 Yaris hatchback, auto trans, non abs.
If I wanted to do this upgrade, what cluster do I need to look for? Anyone have a part # or which model yaris to look for to get a cluster out of? Will a sedan cluster work in my hatchback?
Thanks
beaker is offline   Reply With Quote
Old 09-20-2014, 07:56 AM   #16
Thanks
Sedan cluster is a different shape and has a different connector. You need specifically an 07 or 08 S cluster without ABS. I don't have the part number handy, but there is only one cluster that meets that spec.
For non direct solutions, you can use an 09-11 cluster, but all 09+ have ABS, so the ABS and BRAKE lights would have to be disabled or they would always be on. For 2010-2011 the TRAC light would also have to be disabled.
Old 09-20-2014, 08:36 AM   #17
beaker
Cool, thanks for the answer.
Which of the clusters you have listed above also have the cruise and foglight indicators that I could also utilize when I add these options to my car?
Old 09-24-2014, 08:31 PM   #18
beaker
I'm jealous.
Wish I could find one to put in my car.
Yaris 2 D4D 2009 without AC serpentine belt rasyaya DIY / Maintenance / Service 6 07-17-2014 09:02 AM
2009 Yaris and wind sailing GrayYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 10-26-2013 07:52 PM
how do I install a different headunit in 2006 yaris? wouterw In Car Entertainment + Electronics (audio / video / alarm) 10 05-13-2013 07:55 AM
