Old 09-14-2014, 01:48 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Drive shaft snap ring - OK to re-use?
Looks like I somehow got the wrong inner snap ring for the driveshafts, and I don't really have time to wait until tomorrow to order new ones. The old snap rings are still there, how bad is it to re-use them?
Old 09-14-2014, 08:21 PM   #2
I think it is fine to do so. Just make sure the opening points down when you insert it.
Old 09-14-2014, 08:34 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
^ what he said.
Old 09-14-2014, 11:40 PM   #4
CrankyOldMan
Crap. I didn't check the orientation. Too dark under there when I popped them in. That said, the gearbox is in and seems to be running just fine. Too bad I didn't put match marks on the steering column before disconnecting it...
Old 09-15-2014, 05:49 AM   #5
bronsin
bronsin's Avatar
I think you will be fine!
I got $50 to test drive Cutie Pie #2 Off-topic / Other Cars / Everything else Discussions 6 02-23-2009 09:51 AM
Add another hard drive to a laptop? CompanyXPaladin Off-topic / Other Cars / Everything else Discussions 4 11-23-2008 12:18 PM
Longest Test Drive? lostmind General Yaris / Vitz Discussion 4 05-31-2007 05:20 PM
Floor Mats 4 Aussie Yaris (right hand drive) wanted! YesHapiness Cosmetic Modifications (Exterior/Interior) 6 02-12-2007 07:29 AM
07 yaris liftback and 06 xa test drive extenny General Yaris / Vitz Discussion 12 05-31-2006 11:56 AM
