Old 09-19-2014, 05:53 PM   #1
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
HS Spring Lift and Lowering Kit
Has anyone heard about this? It look like a quick way to lower/lift your car.
It's only $8 so I'm considering it.
Any thoughts?
uploadfromtaptalk1411163487715.jpguploadfromtaptalk1411163494382.jpguploadfromtaptalk1411163502887.jpg
I love the back of my car, the front... not so much
nobodywise is offline   Reply With Quote
Old 09-19-2014, 06:10 PM   #2
nortonfb
Drives: 2007
This not new, it's as old as dinosaur poop.
Yes, it works but it may have a negative effect on ride but it's easily reversed.
Place a few boards under the tire to get the springs together and follow the directions.
Norton
nortonfb is offline   Reply With Quote
Old 09-19-2014, 08:26 PM   #3
bebeelo
ThatYarisGuy
Drives: Toyota Yaris 2012 SE
pictures?
bebeelo is offline   Reply With Quote
Old 09-19-2014, 08:45 PM   #4
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Norton
I wanted to put them on the front springs but that doesn't look possible.
Also, what kinda negative effects would they cause and how would they be fixed?
Originally Posted by bebeelo View Post
pictures?
Haha, if I decide to buy them I will update you
Old 09-19-2014, 08:50 PM   #5
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
Your basically changing the preload of the spring. So it will ride like poop.
mitchell12 is offline   Reply With Quote
Old 09-19-2014, 09:06 PM   #6
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Mehh, I think it's worth a try but only wanted it for the front but there is no space for it
Old 09-19-2014, 11:44 PM   #7
There is a reason it costs what it costs, and people buy springs and/or coilovers instead.
That is simply not the way to lower your car.
Old 09-20-2014, 11:41 AM   #8
aspro
^ what he said...
But at $8 I would get them just to jack the yaris up. I'd like to see what the car looks like lifted. That's would be awesome.
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
aspro is offline   Reply With Quote
Old 09-20-2014, 12:20 PM   #9
I don't think I would necessarily want to use them for purposes of lifting/lowering. What they are good for however is temporarily using them as coil spacers to minimize spring compression if you are carrying a lot of weight in the rear. For that function I personally prefer high density rubber coil spacers.
Old 09-20-2014, 12:52 PM   #10
^ Or shock bump stops -- I sell both. At least there is some give.
With those metal things, the ride... hello Mr. Chiropractor.
Lift springs? j-san Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-10-2014 05:10 PM
