Old 09-25-2014, 09:16 AM   #1
djhuddy2442
djhuddy2442's Avatar
Drives: 2008 toyota yaris hatchback
Help!!!! Help!!!! Help!!!!
I need help. I have a 2008 toyota yaris HB. I put the zage turbo in it. I unplugged the ECU but never cut any wires. I put the ECU plugs back in after we located every wire and tried starting it back up and nothing happened. Now the car wont start at all and no power going to the dash at all.
djhuddy2442 is offline   Reply With Quote
Old 09-25-2014, 09:46 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
First of all, check the connections you made. Second of all, check fuses.
Old 09-25-2014, 10:28 AM   #3
+1 for fuses. Start with the two big ones on the positive battery terminal.
From there, check EFI, AM2, DOME and ECU-B (in the under hood panel).
Old 09-25-2014, 03:47 PM   #4
djhuddy2442
Is there a theft system on the 2008 Toyota Yaris base model hatchback. if yes how do you get past it?
Old 09-25-2014, 04:22 PM   #5
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
There is an immobilizer. Try (this is just my theory) putting the key in the ignition, sitting in the drivers seat, and buckling up.
My bro-in-law did something similar (just google how to deal with an oem immobilizer).
Old 09-25-2014, 05:18 PM   #6
The immobilizer will allow you to crank the engine, but it will not start. Everything else will work though (including everything on the dash).
Old 09-25-2014, 08:18 PM   #7
djhuddy2442
okay so its cranking over then shutting down right after everything on the dash and stereo work.
Old 09-25-2014, 08:27 PM   #8
djhuddy2442
I do not have an immobilizer on my yaris
Old 09-25-2014, 08:43 PM   #9
If it is cranking, starting and then immediately dying, it may be your fuel management. What are you running?
Old 09-27-2014, 01:29 PM   #10
djhuddy2442
Okay so she is alive its was one of the smallest and most idiotic things. The intake pipe fell off the turbo so yeah thanks for the help I really cant believe its was something that stupid.
Old 09-28-2014, 01:04 AM   #11
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Much better it something simple like that than something super expensive.
Colin Chapman disciple
Old 10-03-2014, 01:54 PM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
that can happen. i was stuck in a bind a couple years back and had a shop do an oil change for me. my charge piping runs along the filter point so they had disco'ed my charge piping to add oil. they didn't tighten the charge pipe solid enough so it gave me all sorts of headaches for a couple days and i got really worried...then under load the pipe popped out...yup....that was a funny day.
