Old 04-23-2007, 11:49 PM   #1
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
VVT-i engagement???
anyone here know when our variable valve timing kicks in. im curious as to what rpm/load point it engages the shift. any spec sheets etc. im still breaking my car in so i havnt hit the high rpms yet. thanks
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 04-24-2007, 12:10 AM   #2
spkrman
Drives: 1
its always there :)
Old 04-24-2007, 04:47 AM   #3
yup, it's a continuously variable system. You might be confusing it with VVTL-i, which has a definite engagement point. Confusing stuff, but not as much as Honda which lumps it all under the name VTEC
Old 04-24-2007, 05:08 AM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
Silly Honda guys
Old 04-24-2007, 09:08 AM   #5
Yaris Revenge
GIGA...DRILL...BREAKER!!!
Yaris Revenge's Avatar
Drives: Lagann. ;P
Yeah, standard VVT has a specific activation point. With VVT-i, the "i" stands for "intelligent", which means it keeps the valves timed properly throughout the entire rpm range.
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
Yaris Revenge is offline   Reply With Quote
Old 04-24-2007, 11:08 AM   #6
Some good reading for the technically-minded...
VVT-i / VVTL-i
VTEC
As you can see, Honda has the bad habit of clumping everything they do to valves under the VTEC/i-VTEC banner, while Toyota has four distinct systems, the discontinued VVT, the economy-oriented VVT-i, the more advanced Dual VVT-i, and the performance oriented VVTL-i.
Old 04-24-2007, 08:14 PM   #7
drifto
drifto's Avatar
thanks good info. i was hoping it was a progressive type. honda's vtec is
07 Yaris LB 5spd
