Old 10-04-2014, 01:08 PM   #1
yandpfan
Drives: 2008 yaris
new yaris owner,need suggestions re. noise
Just purchased a 2008 yaris,barebones, 2 dr...after driving a prius for 11yrs. If I want to try to reduce road noise should I start with the hood or trunk and front wheel wells or elsewhere? It would be a diy project, I'm not mechanically inclined, but I do quilt and sew, and some videos I've watched seem to recommend a pieced, layered approach as possibly superior for more inexpensive sound deadening. Would welcome advice re. best products and if I can't do whole car, most effective areas to tackle first. Thanks in advance.
yandpfan is offline   Reply With Quote
Old 10-04-2014, 02:41 PM   #2
bronsin
bronsin's Avatar
My 2009 has the gearshift cable rattle when put into reverse. Drove me nuts when I got it new but Im too old to fix it and my memory is shot so whenever the car goes to the dealer (waterpump went at 25k miles) I forget to tell them to fix it.
Its five and a half years old now and I don't even notice the noise anymore. Before spending $$$ give it a year and it most likely wont trouble you anymore.
Oh BTW Im from Cobleskill and used to go to SPAC all the time!
Old 10-04-2014, 03:15 PM   #3
nortonfb
Drives: 2007
Turn up the stereo.
Norton
nortonfb is offline   Reply With Quote
Old 10-04-2014, 07:11 PM   #4
alanwagen
Tires
If you need tires, look for a quiet tire. That can make a huge difference.
I don't think you can change your Yaris to a Camry.
Old 10-04-2014, 07:32 PM   #5
Quiet tires are a good recommendation. I added a ton of fat mat to one of mine to try to quiet it down and it helped a bit. After that exercise I realized that the most important areas to sound deaden are the fire wall and front wheel wells. Also, I believe that the air intake for the air conditioning is a major culprit. It is a large plastic duct that acts as a direct noise conduit from under the hood to inside the car. Wrapping that in deadening material (and potentially lining it), might be the best way to quiet down the road noise.
Old 10-07-2014, 07:45 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
If you really want to make a project of it pm derickveliz2. He had the single most quiet car I have ever experienced.
Here is his build thread.
Colin Chapman disciple
08 Yaris strange whining noise from either water pump or? Paulywalnuts DIY / Maintenance / Service 9 10-22-2024 07:15 PM
252,000 Miles on Yaris - wierd noise Rutherford DIY / Maintenance / Service 4 04-01-2014 03:15 PM
Yaris engine noise (Video) badmofo DIY / Maintenance / Service 14 02-01-2012 08:33 AM
