Old 10-07-2014, 02:12 PM   #1
ajkochev74
Buzzing Sound From Seat Belt?
Bought the Yaris yesterday really pleased with it.
However the passenger side seat belt buzzes(or makes a vibrating sound) as I drive down the road. Used or not makes driving annoying. I can also make the buzzing sound by pulling and releasing the seatbelt with the car turned off.
Anyone have this issue? Though about taking off the panel and seeing what I can do. Any electronics attached to the seatbelt I should be warry of?
ajkochev74 is offline   Reply With Quote
Old 10-07-2014, 02:16 PM   #2
The front seatbelts have an explosive pretensioner built into the recoil mechanism. That is the only electrical connection in the B pillar for the seatbelt.
That is not powered when the ignition is off, so you may find a bees nest or something like that in the pillar.
Old 10-11-2014, 02:50 PM   #3
ajkochev74
No bee hive in the Yaris.
I took that pillar fascia off today and the sound is definitely coming from the seat belt housing. It is on the left side of the unit with the bright yellow and grayish/beige plastic housings, the electronics are on the opposite side. I could rub my finger gently on the out side of the housing and it made a loud vibrating noise. Checked and it is securely bolted to the frame, nothing loose. It is the plastic housing on the unit.
I took three layers of foam core board and wedged it between the frame and housing. Went for a drive afterwards and the buzz was gone. Weird. The seat belt operates as others in the car the spring recoils it when not in use and I can pull it fast and it locks. No issues with airbag lights or passenger warnings if someone sits there and is using the seat belt. Hopefully this will do it.
Old 10-11-2014, 06:01 PM   #4
There is a metal ball and a plastic mechanism within that area that does the lock on pull process.
With the foam there was actually a recall notice for removing that foam, as it can ignite when the pre-tensioner blows.
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Seat Belt Problem wagon DIY / Maintenance / Service 1 03-06-2013 10:37 AM
Front passenger seat removal & SRS, seat belt issues RMcG DIY / Maintenance / Service 12 11-06-2010 12:43 AM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
