Old 10-12-2014, 01:57 AM   #1
BennyLava
Drives: 1987 Silverado
Glove box door pop open?
Hi all. My glove box door on 2009 Yaris sedan is always popping open. Is there an easy fix for this? Is this a common problem? Every time I rest my arm on there, it will pop open when I take my arm off for a second. I was hoping someone here had already come up with a DIY fix.
BennyLava is offline   Reply With Quote
Old 10-12-2014, 02:41 AM   #2
nookandcrannycar
When this happens in my 2007 Yaris, it means that the glove box isn't 'lined up' properly. Even when it is lined up properly, I sometimes have to push the upper left hand corner of the glove box to get it to completely 'click into place'. I never encountered this issue until after I removed the glove box to install a cabin air filter .
Old 10-12-2014, 08:47 AM   #3
jcboy
Drives: Sedan 07
Its probably just me, but to the OP, did you mean arm rest/center console compartment cover?
This isnt a problem ive encountered, but if anything it should be that the plastic to lock it in place is loose.
Old 10-12-2014, 02:33 PM   #4
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
I think he meant center console, It would be hard for a driver to "rest" his hand on the glove box.
phaznet is offline   Reply With Quote
Old 10-12-2014, 08:41 PM   #5
nookandcrannycar
Both of you are obviously correct. I read 'glove box door' and thought 'I can vent just a little bit about a small peeve' (the glove box never fitting the same after putting a cabin air filter in the empty (from the factory) cabin air filter slot), and didn't pay close enough attention to the rest of the post.
Old 10-17-2014, 11:59 AM   #6
BennyLava
Yeah sorry about that. I didn't read it after I wrote it. It's the center console door.
Old 10-17-2014, 03:54 PM   #7
jcboy
Drives: Sedan 07
DIY fix? i say move expand the screw holes of the metal hinge (that attaches to the cover itself--the part you put your arm on) so that you can slide the cover a little farther back.
Old 10-19-2014, 08:14 PM   #8
BennyLava
Excellent. One of those "duh" moments. Can't believe I didn't think of that.
Dual 8’’ Cargo Floor Sub Box Build Ataristyle In Car Entertainment + Electronics (audio / video / alarm) 18 03-23-2016 01:27 AM
Advantage Drivers Side Glove Box! bronsin General Yaris / Vitz Discussion 15 02-18-2014 12:42 PM
Sub Box Desgin talnlnky In Car Entertainment + Electronics (audio / video / alarm) 5 08-23-2009 01:45 AM
Rubber plugs in glove box cfiimei DIY / Maintenance / Service 5 01-06-2009 04:48 AM
FS: Glove Box Damper (GTA) Teruyume Items for Sale by private party 1 07-02-2007 01:58 AM
