Old 10-12-2014, 12:53 PM   #1
Eduardo_mty
2015 yaris, rear view camera
I Will tray to install this Chinase Rear view camera (picture 1)
I try to remove this plastic, but i can't.(picture 2)
I found this connector, i think this is for rear view camera
Eduardo_mty is offline   Reply With Quote
Old 10-12-2014, 01:35 PM   #2
Eduardo_mty
I found This
Old 10-12-2014, 01:49 PM   #3
Eduardo_mty
And this
Old 10-12-2014, 10:01 PM   #4
Eduardo_mty
Ctscott do you know the part number for this 24 pin connector
Old 10-12-2014, 10:31 PM   #5
No. The camera is not documented in the US wiring diagrams, so that connector is not even shown.
Old 10-12-2014, 10:41 PM   #6
OK - Found the connector in Europe. It is part of a the installation kit for the camera: PZ457-B0140-00 (which includes the harness and pins and the connector.
The OEM camera is: PZ473-B0140-00
Old 10-12-2014, 10:56 PM   #7
Eduardo_mty
Thank you ctscott, in Do you have the link?...
Old 10-12-2014, 11:01 PM   #8
Eduardo_mty
I found pz457-b0140-00, around 60 usd, this is the connector?
http://partsale.eu/spare-parts/view/...14000-74818965
Old 10-12-2014, 11:02 PM   #9
Eduardo_mty
But no the oem camera
Old 10-13-2014, 08:05 AM   #10
Doing a search for the camera part number shows a couple of European sites with it. Try emailing the folks at the link below, as I have always had good luck ordering European Yaris parts from them:
http://genuineserviceparts.com/
Old 10-13-2014, 12:02 PM   #11
Eduardo_mty
CTScott, do you think, this will work
http://www.ebay.com/itm/Toyota-Displ...113b80&vxp=mtr
or this
http://www.ebay.com/itm/OEM-BACK-UP-...64b626&vxp=mtr
Old 10-13-2014, 12:57 PM   #12
The second would not be of use unless you were using an aftermarket radio. The first may work, but I am not sure, as the bare camera (86790-0d010) is a unique part number to the Yaris, where many of the other vehicles with cameras share a common part number.
Old 10-13-2014, 02:01 PM   #13
Eduardo_mty
i will buy
thank you for your help
i will pay the same price for harness, and the shipping .
Old 10-19-2014, 06:28 PM   #14
ucsmfu
Drives: yaris le
i will buy
which reverse camera did you end up buying and using ?
can't you just splice the wire to reverse light signal ?
Thanks
ucsmfu is offline   Reply With Quote
Old 10-19-2014, 07:33 PM   #15
Eduardo_mty
The camera I bought in alibaba.com, 8 months ago
Now i waiting a cable video that bought with autoharnesshouse.com
Old 11-09-2014, 10:40 PM   #16
Eduardo_mty
I got the cable from autoharnesshouse.com and Now i will try to connect.
I connected to the head unit.
I run the cable camera, And + wire, And - wire. To the front of the car.
Brian from autoharnesshouse.com, tell me that i need to use the red wire to power the camera And negative wire i was connected to a screws under the dash
Now i need to connect to reverse wire.
I asked in other post..
And CTScott help me. But i can't found how to connect.
Old 11-10-2014, 12:27 PM   #17
Eduardo_mty
one question.
i will take the + wire, from reverse light, i will run from back to front.
one pin on the harness, is the reverse light trigger, then,
i will connect .. + wire from reverse light, + red wire from harness and +wire from pin trigger?
this is correct?
Old 11-10-2014, 12:49 PM   #18
Eduardo_mty
pictures
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
