Old 10-25-2014, 10:00 AM   #1
ajkochev74
Aftermarket Gauges - Show Me Yours
If you've put a aftermarket tach or other gauge in your car, I'd like to see it on your dash in a picture. Thinking about getting one myself but don't know where to put it
I've been looking at these:
http://www.amazon.com/Auto-Meter-150...teering+column
Anyone use one or similar, there are two gauge ones as well.
I've also thought about getting a OBD 2 HUD, several on ebay, which projects gauges into the windshield but most reviews are not to favorable.
ajkochev74 is offline   Reply With Quote
Old 10-25-2014, 10:22 AM   #2
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
The thing about OBD2 based stuff in regard to gauges is our cars do not have oil pressure senders, They only have an oil pressure switch. Meaning you geat no useful information about oil pressure. Oil pressure and an actual water temp gauge are the only extras I really want in my NA car. ( I have a tach already being a Canadian car)
mitchell12 is offline   Reply With Quote
Old 10-25-2014, 02:47 PM   #3
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
HUDs are cool looking idea, but yeah the reflection sucks. I use Torque app (OBD) on a tablet installed to monitor sensors.
Check out my Build thread:
Old 10-30-2014, 02:41 PM   #4
ajkochev74
Thanks for the replies so far. I would still like to see a few photos of aftermarket gauges installed. I was under the impression several here had installed a tach.
I'd personally want a 2" one. Has anyone installed gauges on their pillars using something like this?
http://www.amazon.com/GlowShift-Univ...productDetails
Old 11-10-2014, 10:41 AM   #5
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Gauges in A pillar from top to bottom; Tach, Boost/Vacuum, Volt. Steering column gauges Water Temperature, Oil Pressure (water temp gauge has since been replaced with an AME wide band air/fuel ratio gauge) Blitz Rvit above rear view mirror. All gauges are Glowshift.
Old 11-15-2014, 08:24 PM   #6
mario98c
mario98c's Avatar
Prosport Premium Series 60mm Water temp and Oil Press.
Old 11-16-2014, 05:45 AM   #7
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
UltraGauge EM
Mittelklasse is offline   Reply With Quote
Motion Auto Show 8/21/11 cali yaris California 2 08-20-2011 12:50 PM
Rockland Toyota's Scion Revolution 4.0 phyre76 NY / NJ/ CT / PA 70 08-11-2010 05:20 AM
ROCKLAND SCION'S FALL FESTIVAL 2009 9/13/2009 ROCKLAND TOYOTA NY / NJ/ CT / PA 18 09-15-2009 10:31 PM
ROCKLAND/SCION SUMMER SLAM 3.0 7/19/09 ROCKLAND TOYOTA NY / NJ/ CT / PA 198 08-05-2009 01:04 AM
Rockland Toyota/Scion Car show Zefoxe NY / NJ/ CT / PA 47 05-26-2009 08:16 PM
