Old 10-25-2014, 12:58 PM   #1
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Engine Rock and Roll.
So I think I've wrecked my motor mounts. I have to admit, since I've installed my Blitz (Thanks again Tolmach, CTScott, and Cali Yaris), I have developed even more of a lead foot. Do the factory motor mounts allow the engine to move fore and aft quite a bit (2-3")? If so, is there a solution to tighten them up a bit? If not, are there replacements that are stiffer but not solid? I've been tempted to take them off and re-bush them with polyurethane as well. Any thoughts on that route?
07stlYaris is offline   Reply With Quote
Old 11-22-2014, 01:05 PM   #2
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Maybe a video of unwanted motion to help. But, I am thinking, maybe a home made torque strut somewhere appropriate would help.
Old 11-22-2014, 08:46 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I doubt you ruined them, the engine is suppose to move a lot. If you look, even the piece that connects the exhaust to the block is flexible.
Colin Chapman disciple
