Old 10-26-2014, 09:18 AM   #1
dihzenyo
Drives: yaris sedan
Exclamation 15x7 25offset
Anyone has this setup?
Any rubbing issues without fender roll or camber kit?
I have a 2" drop on my lowering springs and currently running on a 17x7 45offset, do you guys think that i'll have rubbing issues on a 15x7 25offset?
Can please post pics as well? Thanks!
dihzenyo is offline   Reply With Quote
Old 10-26-2014, 01:20 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I would say so
sent from my S4 on Mars
Old 10-26-2014, 03:21 PM   #3
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
I'm running 15x8 25offset in the front with 195/45/15 falken tyre and in the rear the same with an extra 20mm spacer (so makes it an offset of 5 with 8J). And im on coilovers as low as can be and I have a bit of rub in the back when i ride in a ditch... but just a little bit ;) but i would say, you wouldn't have any rub.
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 10-26-2014, 11:31 PM   #4
dihzenyo
Drives: yaris sedan
with that kind of set up, do you have cambers at the back?
I only have 2" drop, stock shocks, was thinking it might be too low for that tire spec of 195/45/15.
any recommendations?
Old 10-29-2014, 12:44 PM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I run 15x7.5 offset of -30. 205/50/15 I only rub when there is passengers in the back or a heavy load i am carrying, but I also have my fender liners cut out. I am sure they will rub with liners in. Normal driving with just me and/or my wife, no rubbing.
-Derrick-
camber, lowered, offset, rims
15x8? or 15x7? together with coilovers... G-Ammo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 45 02-07-2013 05:18 PM
Yokohama Kreuzer Series XII 15x7 richard7791 Items for Sale by private party 3 05-27-2010 04:46 AM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 08:10 PM
FS: Yokohama Kreuzer Xii Wheels 15x7 +27 4x100 BNIB Toyo Mike Items for Sale by private party 6 07-20-2009 11:22 PM
