Old 10-28-2014, 10:00 AM   #1
gabriel2012
Drives: 2011 Base Sedan
thinking of buying a 2011 w 29k miles need some help
Hi guys, after losing my 2007 HB in an accident I switched to Jeep(baaad move) and now I'm looking at getting back to a Yaris.
There is a guy selling a used 2011 with 29k miles that he had for his house maid to take the kids to school. The car is in great shape, has all vin stickers and smells like new. The airbag light is on, is there a recall on this???
The asking price is $9000
Thanks
http://db.tt/QIWZ2E2 Click to signup for dropbox, and get bonous space, I do too!
gabriel2012 is offline   Reply With Quote
Old 10-28-2014, 10:35 AM   #2
I have only seen the spiral cable (clockspring) recall notice for 2006-2010 Yaris. If you can get your hands on the car for a minute you can read the airbag system code using the following procedure:
http://www.yarisworld.com/forums/sho...d=1#post557473
Old 10-28-2014, 11:13 AM   #3
gabriel2012
Thanks for the reply scott, I may be able to get to it tomorrow, what van I use as a jumper? Ive never done it before, also which pins on the OBD port are which? Is this still covered under warranty? thanks!
Old 10-28-2014, 11:16 AM   #4
gabriel2012
I found your diagram, what can i use as a jumper? I am thinking of taking the vin to the delaer to get it checked out
Old 10-28-2014, 02:36 PM   #5
You can use a small piece of wire or a small paperclip to do the jumping. If the car is still under warranty it should definitely be covered. You can also go to the "recalls" section of Toyota's website and plug in the VIN to find out which apply to it.
Old 10-28-2014, 03:45 PM   #6
bronsin
bronsin's Avatar
Seems a pretty low price I smell a rat!
But here in NJ where there is no inspection other than is the CEL on I would buy it if everything else was good!
Old 10-28-2014, 04:05 PM   #7
gabriel2012
I got under the car and checked the suspension, control arms and bushings seemed fine, checked frame for possible collision damage and everything seemed fine. No CEL at the moment per my Actron OBD scanner which indicates light should be off.
I am going to check the airbag codes per scotts methood tomorrow (hopefully)
Guy was asking for 10k when He started negotiating with me. Its a base model with power nothing.
Old 10-30-2014, 04:22 PM   #8
gabriel2012
thanks for the tip scott, managed to reset the airbag light, I couldnt read the code though.
I took it to my friends body shop today and he found that the yaris had been in a small impact on the drivers rear side. He did say there was no frame damage and the repair was done properly(so good I didnt even notice it), I told this to the owner and haggled him down to 8k. My guy looked at every other inch of the car and couldnt find anything else wrong with it. All VIN stickers are present so I pulled the trigger
Old 10-30-2014, 08:20 PM   #9
Nice. If it cleared and doesn't come back, then the problem was likely resolved, but they didn't reset the SRS ECU.
Old 10-31-2014, 07:04 PM   #10
DonM
Drives: 2008 Yaris sedan, 5 speed
Thanks
I just received my recall letter today re the spiral cable and the letter mentions that if the spiral cable is defective - that the air bag light will come on....so that may be the reason - at any rate the recall is for all 2006-2010 Yaris so you are covered for the repair.
DonM is offline   Reply With Quote
Old 11-03-2014, 07:49 AM   #11
gabriel2012
So far so good, after they guy had it reset(don't know how, but I do know the light wasn't unplugged from the cluster and everything else is acting good)
I've driven 250 miles with and without a passenger and the system has been behaving as expected. (weight sensor working when passengers sit/exit the vehicle).
I checked for any recalls and for my VIN there are none.
The things the car had when I bought it:
Rear drivers water leak by taillight/trunk seem - Fixed with silicon by applying a nice big coat outside and inside the vehicle.
Rear drivers side bumper reinforment bar support - It was a bit smashed for the impact, I ordered a new OEM toyota(body shop buddy gets 40% on all OEM parts) one along with the shock absorbers for the bar.
Acc belt squeak - Gone after re adjusting the tension on the alternator, belt seemed fine.
I'm in love with this little sedan after having my 07 HB totaled
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Man hits 1 MILLION MILES in Ford F-250... in four years!!! Kal-El Off-topic / Other Cars / Everything else Discussions 6 10-30-2010 10:19 AM
Also thinking of buying a Yaris TwoBearWisconsin New YARIS Purchase Forum 34 10-13-2009 02:11 AM
What's ur longest drive in a Yaris without stopping(cept gas)? Yawesh General Yaris / Vitz Discussion 46 04-21-2009 01:36 PM
