Old 11-02-2014, 12:51 AM   #1
xmanf14
Drives: 2013 Yaris
Engine rev limiter override
Hello:
I have a 2013 Yaris with a manual transmission. California emissions. Does anyone have any experience in attempting or successfully bypassing the rev limiter on this vehicle?
xmanf14 is offline   Reply With Quote
Old 11-02-2014, 09:15 PM   #2
The Yaris ECM has a hard coded rev limit. To bypass it requires running a stand-alone ECM.
Old 11-03-2014, 08:42 AM   #3
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
In some older yotas you could change out the crystal on the ecu. However I am fairly certain any attempt at a similar mod on these ECUs would be difficult and if possible probably mess something else up too since I always thought it chanfe the clock speed of the ECU... might not be the right term.
mitchell12 is offline   Reply With Quote
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
1kr-fe engine wiring boothybunch DIY / Maintenance / Service 0 03-28-2011 03:59 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
rev limiter mastaofdisasta Performance Modifications 2 11-24-2008 03:10 PM
