Old 11-05-2014, 04:20 PM   #1
Gpav6
Drives: Yaris sr
Yaris mk1 cd/radio audio system not working after battery removed
So I had to reset my ecu after having the engine management light on due to a bar maf sensor which i then replaced and reset the ecu by removing the positive wire that goes to the battery. I removed this for 10 mins after which everything reset including the ecu, job done i thought until now.
I now cannot do nothing with the radio or cd player, although i can change station it does not work, even when i press steering wheel buttons i cannot change volume , there is no volume.
Even when i press eject on the cd player it does not reel it in.
Prior to this everything was working.
Is this a code issue or has the fuse blown?
Edit: its a yaris mk1 2003 t-spirit eith a standard toyota cd / radio system
Gpav6 is offline   Reply With Quote
Old 11-05-2014, 08:09 PM   #2
The MK1 radios did not have a security code, so check the ACC and DOME fuses.
Old 11-07-2014, 09:44 AM   #3
Gpav6
Drives: Yaris sr
Any idea how to check and fix this?
Old 11-07-2014, 09:52 AM   #4
Were those two fuses OK?
Old 11-07-2014, 05:50 PM   #5
Gpav6
Drives: Yaris sr
The acc one under the dash was ok but the dome fuse (under bonnet fusebox) is missing. Any idea what ampage the dome fuse is?
I do not understand , before i removed car battery everything worked.
Please help me.
Old 11-07-2014, 07:48 PM   #6
Please help me.
DOME is a 15A fuse. Very strange that it is missing.
Old 11-08-2014, 10:44 AM   #7
Gpav6
Drives: Yaris sr
Turns out it is the h-ip main 20a fuse that was missing.
I checked amp and dome and both are ok.
Cd/radio still not working
Old 11-08-2014, 07:13 PM   #8
That makes more sense. Have you tried disconnecting the radio or pulling the dome and ACC fuses for a couple of minutes to try rebooting it again?
Old 11-08-2014, 09:29 PM   #9
Gpav6
Drives: Yaris sr
Ok thanks for that , i tried taking the fuses out and I even replaced dome fuse but nothing has changed. I will try disconnecting radio tommorrow.
Any other ideas?
Old 11-08-2014, 09:54 PM   #10
Any other ideas?
Beyond that, I'd say that the radio must have an internal problem that occurred during the battery replacement.
Old 11-09-2014, 01:21 PM   #11
Gpav6
Drives: Yaris sr
Ok I took the cdplayer out and it seems to be a faulty cable at the back, some times when you wiggle it , it works and other times it doesn't.
Here's a pic
Any ideas?
Old 11-09-2014, 08:35 PM   #12
Look a the pins on the connector to see if they are deformed where the holes are too large. If so, you can reshape them with a tiny screwdriver.
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Upgrading the audio system in my 2008 yaris Fleurg In Car Entertainment + Electronics (audio / video / alarm) 8 07-10-2014 11:41 PM
