Old 11-09-2014, 08:08 PM   #1
Eduardo_mty
CTScott.. broken parts
CTScott, do you have this part? 82819-0D070
i searching on the internet and i cant found it
Eduardo_mty is offline   Reply With Quote
Old 11-09-2014, 08:17 PM   #2
That part is actually just considered part of the hatch wiring harness, so you can't purchase it separately from Toyota. I had one but sold it a while back to someone who did the same kind of damage to his.
Old 11-09-2014, 08:29 PM   #3
Eduardo_mty
Thank you.... Its the same for others years, to search on yunkyards here in México
Old 11-09-2014, 08:45 PM   #4
That looks identical to 2nd generation ones, so you should be able to use one from 2006 to present.
And, it is easiest to remove it without damage by squeezing it from below (getting above the head liner).
Old 11-11-2014, 12:59 PM   #5
Eduardo_mty
Ctscott, this part have a name, i try to ask on Internet yunkyards.
Here in México i can't found it
Old 11-11-2014, 02:49 PM   #6
I have never seen a definite name for the white part, but I would inquire about the hatch wiring harness, as it is part of that assembly.
Old 11-12-2014, 03:22 PM   #7
Eduardo_mty
$ 50 usd for this part, is good price... i found one in mexico
Old 11-14-2014, 12:17 PM   #8
Eduardo_mty
How i will install the White piece
Old 11-14-2014, 12:36 PM   #9
joell
joell's Avatar
Drives: 2013 Hatchback
Isn´t a two piece part like mine (third gen hatchback), looks like you will need to remove the wiring before inserting in the body of the car.Search for diagrams that can give you a better idea.
joell is offline   Reply With Quote
Old 11-14-2014, 01:01 PM   #10
If I remember correctly the connector ends fit through the white piece, but it has been a while since I had one in my hands.
Old 12-11-2014, 02:14 PM   #11
ucsmfu
Drives: yaris le
won't the wire fit through this plastic part ?
ucsmfu is offline   Reply With Quote
Old 12-11-2014, 02:19 PM   #12
Eduardo_mty
When i did that, i dont know how to remove, i pull from "outside" to inside and broken that piece
Old 12-11-2014, 02:25 PM   #13
Eduardo_mty
Look
Old 12-11-2014, 02:27 PM   #14
Eduardo_mty
You need to remove a little ceiling to remove this White plastic
Old 12-11-2014, 03:38 PM   #15
ucsmfu
Drives: yaris le
i was able to feed both wires through the plastic piece. I didn't need to remove it.
My question now is how do I put the black grommet back in place ? The bottom part of the grommet which goes over the plastic part.
Thanks
Old 12-11-2014, 06:31 PM   #16
Thanks
You have to remove the white part to get the black part back over it correctly.
Old 12-11-2014, 09:27 PM   #17
ucsmfu
Drives: yaris le
what's the best way of removing it properly ?
thanks
Old 12-11-2014, 09:32 PM   #18
thanks
Pull the rear part of the headliner and release it from below.
Have you noticed that parts are hard to find for the Yaris? grampi DIY / Maintenance / Service 2 09-06-2014 12:42 PM
broken blitz supercharger needed for parts, for 1nz-fe biffy Willing to Buy by private party 13 02-10-2014 03:28 PM
Yaris Super trip to buy aftermarket parts / 1500miles (2547km) in 36hrs / Pictures 3cyltrbo General Yaris / Vitz Discussion 10 11-07-2012 09:09 AM
