Old 11-10-2014, 04:01 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Unhappy Incorrect outside temperature reading
Hi all.
I am almost done with my instrument cluster swap.
I've noticed though the outside temperature reading is off. Its strange. It worked initially but now it doesnt work. it seems to be off by 10c. So when its 18c it shows 8c.
Its not the sensor because I changed it and still same problem, however if I wire the sensor directly to the meter, it shows the correct reading.
Any ideas on what I could check ? worst comes to worst I will just wire up an extra sensor directly to the meter, though I'd really like to avoid that.
Cheers
JudgeM is offline   Reply With Quote
"Catalyst mon" incorrect on ODBII reader Pingouin DIY / Maintenance / Service 0 11-09-2011 02:51 AM
ATX temperature overheating? yaryarbing Fuel Economy Forum 7 05-07-2011 09:24 AM
Temperature Guage install bieniman DIY / Maintenance / Service 3 03-12-2009 02:45 PM
Water temperature Bob_VT General Yaris / Vitz Discussion 11 11-03-2008 03:17 PM
