Old 11-12-2014, 07:36 AM   #1
guybloom
Drives: Toyota Yaris
205 40 17 Feedback Needed
I own a 1.5 Yaris hatch and I am thinking about fitting 205 40 17 on stock suspension 17 x 7. I live in Sydney Australia where the roads are relatively good but I am still concerned that these would result in a very rough ride. Could anyone who have fitted this size on their Yaris comment on the comfort of the ride.
guybloom is offline   Reply With Quote
Old 11-12-2014, 08:18 AM   #2
Comfort is subjective. Coupled with the soft stock suspension you will still be fine, tho definitely not as cushy as stock 15s. Recommended 205 tire sizing on a 17x7 is 45/17 which will give you a little bit more sidewall.
Old 11-12-2014, 04:05 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
If you're running stock suspension, I'd definitely run 205/45/17's.
Toyota OEM is 205/45/17 on TRD suspension.
Old 11-13-2014, 04:53 PM   #4
guybloom
So is there any rubbing of any kind with 205 45 17 on 17 x 7 on stock suspension
Old 11-13-2014, 05:24 PM   #5
If the wheels have the correct offset, no. Stock offset is +45
Old 11-15-2014, 03:57 AM   #6
guybloom
Thanks for all your comments and feedbacks. If anyone else has fitted 250 45 17 , 17 x 7 on their 1.5 Yaris hatch please free to comment on the ride in relation to acceleration handling and comfort. Your response would be much appreciated.
Old 11-16-2014, 03:43 PM   #7
guybloom
Will 205 45 17, 17 x7 rub on stock suspension on a 1.5 Yaris hatch ?
Old 11-16-2014, 04:39 PM   #8
Read post #5
Old 11-17-2014, 06:12 AM   #9
alias06
Drives: 2008 Red Toyota Yaris
I'm in the process of getting some 205/40r17s for my Yaris also. The wheels I got are also 17x7 but I am unsure of the offset as was the previous owner. He had 2 bald 205/45r17s on there that I test fitted and ran for a few miles. The ride didn't feel much different from my current setup of 15x7 wheels with 185/60r15 tires. I did notice a slight difference in acceleration though, not sure if it was due to the different gearing caused from the overall diameter change or if the wheel/tire combo was lighter than what I was running. Unfortunately for me I won't be able to give any feedback about the set up since it is snowing here and wider tires are just asking for trouble.
alias06 is offline   Reply With Quote
Old 11-18-2014, 07:06 AM   #10
guybloom
Thanks for your feedback. How would you describe the slight acceleration difference between 185 60 15 and 205 45 17. I have changed from 185 60 15 on steels wheels to 205 55 15 alloy wheels around 5 pounds heavier per setup and I easily fell a difference in acceleration. Also why are you going with 205 40 17 and not staying with 205 45 17.
Old 11-19-2014, 02:12 AM   #11
alias06
To me the car felt more responsive to throttle input, especially in stop and go traffic it took less effort for me to the the car moving from a redlight. The reason that I want to go to 40s instead of 45s is mainly due to the difference in the overall diameter height, with the 45s the difference is roughly 1/2" larger while with the 40s it is about 1/4" smaller, while with both there'll be a small difference in the reading of the speedometer the smaller diameter should result in a gear reduction allowing more torque to the wheels (faster acceleration) with lower top speed which I believe should "free up" some response from the engine. Just my $0.02
Old 11-19-2014, 06:41 PM   #12
guybloom
Having such low profiles 40. Is your ride rough ?
cost effective sensible mods help needed macguyver Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-01-2012 10:21 AM
205 45 16 trx73 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-06-2010 08:18 PM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 10:11 PM
Penguin Garage Feedback thread Penguin Garage Penguin Garage 16 06-23-2009 01:30 PM
Feedback needed on wheels kimona Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-09-2007 02:22 PM
