Old 12-03-2014, 10:31 PM   #1
Caramanos2000
Drives: 2012 Yaris 5dr Hatch
Shifter cage bushings?
Ok, first of all I want to know if the bushings on the shifter and the cage for the 2nd gen and 3rd gen are the same? I was looking at pictures of the cage bushings and pricing, they work out to around $40 shipped to me. Couldn't such a simple part be made out of a few stainless washers and some pvc pipe? After all, all the solid bushings do for the cage is give it solid feet per say, couldn't I accomplish the same thing with $4 in pvc, bolts and washers?
Caramanos2000 is offline   Reply With Quote
Old 12-03-2014, 10:58 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
Not sure if they are the same but so long as you can get the shifter cage bolted securely, that's all that matters. I didn't notice that big of a change when I did mine, but my cage bushings were still in good shape.
Cheers.
Old 12-03-2014, 11:00 PM   #3
Caramanos2000
My car doesnt even have 10k on it yet but I have extended the shifter by 3" so im concerned the added strain is causing extra flex, what are your thoughts?
Old 12-04-2014, 12:35 AM   #4
CoryM
It's really up to you. If you are a typical driver who just needed the extension to drive more comfortably, I'd suggest not worrying about it. If you want the extension and the best viable shifter feel, then go for shifter bushings, SSK, cage bushings (in that order of importance).
Cheers.
Old 12-04-2014, 05:39 AM   #5
mr_miles
Drives: 2013 Yaris
They will fit a 3rd gen. I'm using them right now on mine. I like the feel :)
Old 12-04-2014, 10:29 AM   #6
washers will be a cheap solution, but not the same as solid bushings.
I would do the cable bushings first, they have more of a "feelable" effect than the cage bushings.
You can even bolt your cage to the floor for FREE with no bushings at all - but you lose a little height.
aem intake blue/tanabe medallion/ shifter bushings mastaofdisasta Items for Sale by private party 11 10-29-2014 06:59 PM
The MI SSK "Not a Big 'Car Guy'" Review jpmck03 Performance Modifications 36 09-19-2013 11:41 PM
NST Cage Bushings for sale fnkngrv Items for Sale by private party 3 09-06-2013 02:01 PM
Bronzoil Cable Bushings for the Yaris/Echo now available! TWM Performance TWM Performance 58 03-31-2010 10:19 AM
NST shifter linkage bushings... DerFlosser Performance Modifications 4 05-21-2009 08:33 PM
