Old 12-10-2014, 09:47 PM   #1
roc
Drives: Yaris YR 2006 3-door hatch
Exclamation help needed - 06' Yaris YR power loss on freeway
Hello,
I bought this 2006 yaris YR 3-door hatch with 143,000 kms on the odometer last week from a used car dealership and I am having some annoying power issues
During test drive everything was fine, but then right after I have paid for the car and was driving back home on the freeway doing about 90 km/h, the engine started shaking, car started to lose power and could not go anything faster than 30 km/h. None of the warning lights lit up on the dashboard when this happened.
I pulled over and immediately called the dealer about the issue, and he told me it was because of bad fuel clogging the fuel filter. He asked me to switch off the engine and wait for half an hour for the impurities to settle which I did, and the car started going again and could do about 60 km/h, but the engine was still chugging when the car was idling, as if it would die in any second.
Car was low on fuel so I pumped premium fuel into the tank and slowly made my way to a mechanic who is a friend of mine. He did a check for me and measured low fuel pressure. Thanks to statutory warranty, I took the car back to the dealership and had him replace the fuel filter and fuel pump for me, but then the same thing happened again on the freeway and this time I could smell something burnt in the engine after I opened the hood.
TL;DR, to summarize:
- Car was fine before going onto freeway;
- Car starts to lose power after doing about 90 km/h on the freeway for a while;
- After power loss, car could not go anything above 30 km/h even if I floor the pedal;
- Car started going again after I turned off the engine and waited for half an hour;
- Engine was shaking and chugging when car was idling as if it was going to die in any second;
- Quick check shows low fuel pressure;
- Replaced fuel filter and fuel pump but problem persists;
- Burnt smell from engine after I opened the hood.
What else could be the cause of all this other than fuel pump and fuel filter? Thank you very much in advance for any insight that can be provided on this matter!
roc is offline   Reply With Quote
Old 12-10-2014, 10:01 PM   #2
The burnt smell under the hood would concern me. That should definitely be checked.
Also, I would have your mechanic plug in a diagnostic tool to make sure there aren't codes stored and someone disabled the indicator light.
Old 12-10-2014, 11:02 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Pluged catalytic converter would be my guess
Old 12-10-2014, 11:08 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Also if that is the case it maybe under emissions warranty think its up to 160k on Toyota .
Failer may have been coused by bad fuel or plugs having unburned fuel to overheat the converter .
Old 12-10-2014, 11:58 PM   #5
roc
thank you so much for the replies! The car is with the dealer's mechanic now, I will make sure he checks the catalytic converter and runs a OBD scan, and all the other possible causes ..
My own mechanic also told me it may be a electric problem which can be very expensive to fix ... will update you guys if there's any progress
Old 12-11-2014, 07:45 AM   #6
I'd be asking for my money back.
Old 12-11-2014, 05:26 PM   #7
roc
Exactly and I would like to do that too, but by law I have to give the dealership an opportunity to try and fix the vehicle first, to prove the problem is a "major problem" that cannot be fixed within a reasonable time
Old 12-11-2014, 08:48 PM   #8
I'd say them replacing the fuel pump and it doing the same thing is cause enough.
Old 12-12-2014, 01:49 PM   #9
Kitt
Kitt's Avatar
Same happened to me once but it was a faulty ignition coil, however, it did gave me a check engine and the engine stopped.
Old 12-14-2014, 05:29 AM   #10
roc
Update: Dealer tested the car himself and ran into the same issue, this time with a check engine signal. Mechanic ran a scan and found an issue with the air flow meter .. they are still testing the car for now
Old 12-14-2014, 02:01 PM   #11
When I modified my stock air box I didn't properly connect MAF sensor back when reinstalling. About 20km into driving it must have popped off partially. Car would drastically lose power when slowing off throttle and then chug really hard and die. It would start normally and ten 10seconds in do the same thing. Reconnected MAF and issue was gone.
I don't remember the code it threw bit it would have been your typical MAF code. It is possible that it may be a faulty MAF? Hopefully they can figure it out
Old 01-09-2015, 12:24 AM   #12
roc
Angry
Update: Finally I have a working car!
Dealership ended up replacing, in chronological order, fuel pump and filter, air flow meter, coil pack, gear box, engine and ECU and finally the power loss problem is gone. Not exactly sure which component caused the issue but most likely it is the gear box. Also unsure how I am gonna explain all this to future buyers when I am selling this car ...
But now I end up having two different sets of keys! The 2 old keys (plain keys attached to a plastic fob) open car doors but cannot start the car, and the new key (with a keyless entry remote) starts the engine but does not open car doors.
Does that mean I have to change the car door locks (!) or is there anything else I can try?
Old 01-09-2015, 03:42 AM   #13
colj00
DIYer
Drives: yaris 1.5 MT
they replaced the gearbox and engine!?!?
colj00 is offline   Reply With Quote
Old 01-09-2015, 07:22 AM   #14
Looks like they also replaced the ignition switch.
Old 01-09-2015, 09:34 AM   #15
wow. other then the double key issue that's not a bad deal for you, new engine!
just keep the ignition key in a hidden spot in your car and walk around with the door lock key. Just make sure your doors are locked and that way you don't have the hassle of always lugging around 2 keys
Old 01-09-2015, 11:28 AM   #16
Don't be lazy. It's just a key. And op have keyless entry. Just keep both keys on you.
Old 01-09-2015, 12:24 PM   #17
Kar98
Drives: 2011 Scion tC
LOL, just like in the olden days, when I had a key for the ignition, another one for the doors and trunk and another one for the filler cap.
fuel filter, fuel pump, power loss
Keyless Entry on Yaris w/o power locks question rhumphrey205 DIY / Maintenance / Service 4 12-03-2011 06:46 PM
YARIS PARTS NEEDED!!!!! zah UK 1 04-05-2010 06:19 PM
