#1 |
![]() ![]() Drives: yaris hatch is the sh*t Join Date: Jan 2013
shifting in high rpm's
does anybody have problems shifting up or down in the higher rpm's?
even in my brand new transmission it seems like i cant drop a gear to get around someone who is driving to slow without grinding second. just wondering.....that is my only complaint about my yaris. i havent had any issues like that in my subaru or gti or any other 5 speed.... |
shifting down to 2nd is pretty awful for me too. 5-4-3 is awesome...but 2...not so much.
#3 |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
i drop down to second at 30-50 mph occasionally. ive never had a problem with it.
#4 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
I don't think I've ever had issues shifting down to 2nd at 50mph. But you are at a very high rpm at that speed. So you really need to rev match.
#5 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
Yea, what IllusionX said. Rev matching will fix it.
-Derrick- "Racing is important to men who do it well. When you're racing... It's life. Anything that happens before or after, is just waiting." |
#6 |
rev matching doesnt help second gear, every other gear is fine. im honestly thinking it might be that the slave cylinder. that has gone out twice already.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
#8 |
DIYer
Drives: yaris 1.5 MT Join Date: Oct 2014
iv never had my yaris grind a gear, and i do track days.
except for one time when my friend got high and thought he would be helpful by putting my car in reverse for me.... without the clutch ![]() ![]() my car is just under 60k miles. even my corolla which is 175 000 miles and 24 years old doesn't grind gears. |
#9 |
my car has both a brand new motor and transmission. i figured out what was wrong....when i replaced both i left one of the subrame mounts un-torqued and it came loose so it was making a knocking sound so i got underneath there and tightened it down and when i was under there i noticed a huge puddle of gear oil sitting on the splash guard and saw that the tranny is leaking fluid so im going to break it open and re-seal it and close it back up. but for now i have topped off the fluid and driving it until this weekend for when i have time to pull it out. i think while im there im going to hand make a new splash guard because mine is all torn up and ugly.
#10 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Make sure the clutch is disengaging properly especially since everything is apart. Also rev matching helps.
I grind my gears everyonce in a blue moon due to a random retard moment or wet shoe
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#11 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
The only one I've ever had refuse to engage is 1st, but only if travelling over about 10 mph. I do occasionally grind 2nd or 3rd, but that's always because I mis-shift or drop the clutch too fast.
Re-sealing the gearbox is a non-trivial project. Are you sure it's between the sections and not just a shaft seal? |
#12 | |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| High RPM's in 3rd. Need some opinions | falkor_99 | General Yaris / Vitz Discussion | 3 | 05-16-2007 08:23 PM |
| RPMs high when cold, not switching gears | donairs | DIY / Maintenance / Service | 11 | 12-12-2006 02:43 PM |
