Old 12-20-2014, 12:57 PM   #1
duendeverde
Drives: Yaris 2010 Manual
Time to change clutch?
So a few days ago my car biting point was low (pedal near the floor) and suddenly it started to get higher (pedal halfway). The biting point feels soft like it's slipping. I have a Luk clutch that i bought at amazon just in case since I bought the car used :/ Just for curiosity, are these signs that the clutch at some point is going to fail?
Also, is $300 fair enough for a clutch replacement (labor) in 1 day?
duendeverde is offline   Reply With Quote
Old 12-20-2014, 01:11 PM   #2
If it is not slipping when in gear and driving, don't change it.
Old 12-20-2014, 05:20 PM   #3
duendeverde
Me personally I want to change it before it start slipping more since I use the car daily for work (100+ miles), probably i can get a few miles from it (5,000 to 10,000)
I was reading post that sometime it's caused by the master cylinder or slave
Old 12-20-2014, 11:00 PM   #4
colj00
DIYer
Drives: yaris 1.5 MT
if you accelerate up to 6k rpm in first, and quickly change into 2nd gear letting off the clutch very quickly and the revs go down slowly instead of instantly then the clutch is going bad. another thing you would notice is the car shudders if you use too much throttle getting off the line.
colj00 is offline   Reply With Quote
Old 12-20-2014, 11:06 PM   #5
colj00
DIYer
i forgot to add the biting point shouldn't change within just a few days, look up at your pedal box, and if you see liquid (often blue, green or mustard yellow) coming from where the pedal connects to a push rod that goes into a black rubber ring, then your master cylinder is bad... under the hood, have a look at your slave cylinder and squeeze the rubber boot hard and thorough, like your trying to juice an orange. again if said liquid comes out then it means a new slave is on order.
Old 12-21-2014, 10:20 AM   #6
Actually how I test a slipping clutch, stand still and rev to 3500rpm and dump the clutch in 3rd. It you don't stall, then your clutch is definitely slipping.
Old 12-21-2014, 10:53 AM   #7
colj00
DIYer
ah ok. same as ETCG's method kinda.
Old 12-21-2014, 11:12 AM   #8
duendeverde
I bleed the slave cylinder with help (someone pressing the clutch pedal). The biting point return to normal (for me)
As for the clutch, in first gear if i take the clutch pedal out o know is going to stall since the car shudder
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 04:48 PM
Hang Time: Exploiting ECU Fuel Maps for Fuel Efficiency BailOut Fuel Economy Forum 20 11-13-2013 09:11 AM
7-17-09 Last Day for Time Attack Event @ CFRC SAKU Tracking, Racing, Auto-X Forum 1 07-14-2009 03:10 PM
Oil change time intervals PaidTimeOff DIY / Maintenance / Service 17 01-29-2009 08:14 PM
