Old 01-02-2015, 09:05 PM   #1
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Exclamation Excessive engine movement
Hey guys,
I have a serious problem.
Whenever I launched my car or dump the clutch, the engine bangs against the firewall.
I'm now afraid that I may break something. My friends told me changing the rear engine mount to a solid mount would solve the issue. Another option would be an engine damper however I can't find any for my car.
What do you guys think?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 01-02-2015, 10:03 PM   #2
KTS
KTS's Avatar
Drives: Vitz RS
Your friends have the right idea. It sounds like the mount(s) are busted.
You can purchase a universal tq damper or one from another vehicle and fabricate custom brackets. U can use a piece of pvc piping or paper towel roll to determine where you want to mount the damper and what length damper to purchase. I believe there are 2 different length dampers available.
KTS is offline   Reply With Quote
Old 01-03-2015, 07:03 AM   #3
Ryze268
Ryze268's Avatar
Sounds like a plan, I'll see what we can do
Old 01-04-2015, 09:01 AM   #4
micro image sells the TRD transmission mount. Might be worth it if your hard on the drivetrain. An engine damper only slows the movement of the engine.
Old 01-05-2015, 05:52 AM   #5
Ryze268
Ryze268's Avatar
Thanks much, could you post a link to it plz?
Old 01-05-2015, 06:28 AM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
http://shop.microimageonline.com/TRD...RIS-trd-mm.htm
There should be a link to the lower trans mount at the bottom of that page.
Old 01-05-2015, 02:20 PM   #7
Ryze268
Ryze268's Avatar
Thanks much, Looks like I need to do some saving.
Old 01-05-2015, 06:56 PM   #8
KTS
KTS's Avatar
Drives: Vitz RS
I have an idea that will be a lot cheaper.....don't launch the car or dump the clutch
Old 01-06-2015, 06:01 AM   #9
bronsin
bronsin's Avatar
Quite. Especially after replacing broken parts!
Old 01-06-2015, 09:33 PM   #10
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Might be mistaken, but I think that I got the last dogbone TRD trans mount that Garm had. He still has the 2 engine mounts. rather than fabricating mounts why not look to get used ones if you don't wanna buy new? Have you checked ToyotaPartsZone.com for OEM?
P.S. Yup, I am still alive and kickin, haha
Old 01-06-2015, 11:29 PM   #11
mario98c
mario98c's Avatar
I filled my engine mounts with 3m urethane lol The engine moves but not a lot like when it have the oem mounts. Also there is a little vibration when the car is at idle. For 30 bucks I think is the best you can do. lol
Old 01-07-2015, 12:41 PM   #12
KTS
KTS's Avatar
Drives: Vitz RS
yup the 3m urethane works good and the vibration is not bad at all. almost no one but me notices the vibration
Old 01-07-2015, 08:00 PM   #13
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
I'm going with the 3M this weekend if it doesn"t work engine damper My luanches at the track are bad and burnout also... to much torque
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-12-2015, 07:30 AM   #14
Ryze268
Ryze268's Avatar
Did you fill all the mounts or just the one at the back?
Old 01-12-2015, 05:30 PM   #15
mario98c
mario98c's Avatar
I fill the transmission mount and the back mount also. I have some pictures of the entire process. I post them later.
Old 01-12-2015, 05:41 PM   #16
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Great!!! Love to see pics also
R-CaT
Project Yar 2ZR
Old 01-13-2015, 06:26 PM   #17
mario98c
mario98c's Avatar
Sorry for the delay.
This is the urethane that I used.
To remove the transmission mount you need to remove the battery and the battery bracket. It's easy to remove. You need to put a jack stand to hold the engine and then remove the mount. To remove the back engine mount you don't need a jack stand.
Before
After
I don't have pictures of the back engine mount but it's much easier to remove that the transmission one. Also you need to let the urethane cure 24 hours.
Old 01-13-2015, 07:15 PM   #18
Ryze268
Ryze268's Avatar
Really appreciate the posts mario
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Can I change my yaris engine from 1.3L to 1.8L Rami yaris Performance Modifications 9 06-11-2012 10:21 AM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
