Old 01-05-2015, 11:56 PM   #1
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Will the prius engine bolt up??
I've read about the piston swap but what about the whole engine? Can the block be bolted directly to the yaris transaxle? Isn't the electric portion just an add-on between the engine and transmission? Just thinking if one could just throw a junkyard Prius engine ( high compression) under the hood and bolt up the ancillaries.
07stlYaris is offline   Reply With Quote
Old 01-06-2015, 11:38 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
this question would require knowing whether or not you are talking auto or manual.
Old 01-07-2015, 02:32 AM   #3
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
How about the Atkinson process and the iirc low torque on low RPM?
The prius has a CVT to be able to run at high enough RPM most of the timr and sone electric torque support.
I drive, therefore I am.
Old 01-08-2015, 09:23 AM   #4
You guys clearly have no clue on how the Toyota Hybrid Synergy Drive works.
The prius engine is not simply a high compression engine, it uses high compression pistons to compensate for the simulated Atkinson cycle the camshafts create. The transaxle is only continuously variable because it has 3 inputs into a planetary gear set, the ICE, MG1 and MG2.
Yes, the engine will "bolt up" to whatever yaris transmission you want because its the same 1NZ block but the computer will not be able to run it.
Old 01-11-2015, 01:54 PM   #5
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Yes they do bolt on, 13:1 comp
I Drive a 129whp Yaris ;)
Prius Pistons sdyaris Performance Modifications 118 04-02-2013 01:38 AM
1kr-fe engine wiring boothybunch DIY / Maintenance / Service 0 03-28-2011 03:59 AM
