Old 01-06-2015, 05:19 PM   #1
Yarisgirl1964
Yarisgirl1964's Avatar
Drives: 2008 Yaris
Cold weather and the Yaris
I have a 2008 Automatic sedan. This is my first winter with it. A few times in the cold weather when I start the car at cold, it makes a horrible grinding noise, as if I am turning the key with the engine already on....anyone have an idea? Or have you experienced this also?
Yarisgirl1964 is offline   Reply With Quote
Old 01-06-2015, 07:08 PM   #2
Kar98
Drives: 2011 Scion tC
Can't say as I do. It takes maybe a turn more than in summer driving and I actually have to depress the gas pedal some, but no grinding noises.
Old 01-06-2015, 08:35 PM   #3
nortonfb
Drives: 2007
Grinding noise is either the motor is running, the starter armature is sticking,
the key is sticking or being held too long.
See if you can isolate what is happening.
I had a problem two or three times where the starter stuck on my current
07. I just shut it off and restarted it.
Hasn't happen since the weather got cool/cold.
Norton
nortonfb is offline   Reply With Quote
Old 01-07-2015, 06:03 AM   #4
bronsin
bronsin's Avatar
Where do you live? (how cold is it?) If it doesnt do it very often (1 time in 10) I wouldnt worry about it.
Old 01-07-2015, 10:15 AM   #5
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Could that grinding noise actually be a loud squealing noise?
Have Yaris will travel..
Old 01-07-2015, 10:43 AM   #6
nookandcrannycar
Yeah, with a 2008, if the serp belt hasn't been changed it might be slipping.
Old 01-07-2015, 05:28 PM   #7
Yarisgirl1964
Drives: 2008 Yaris
It seems to happen when there's a lot of moisture and cold. So, not often...as it was really cold this morning and this afternoon and it didn't happen.
Old 01-07-2015, 05:28 PM   #8
Yarisgirl1964
Drives: 2008 Yaris
Nope, not squealing
Old 01-10-2015, 03:26 PM   #9
Duhamhim
Drives: 2008 Yaris sedan Base
Has anyone ever had the steering rack seize during extreme cold (9°) NYC
Had to replace one same time last year after nearly catastrophic failure (turning wheel car still going straight)
Duhamhim is offline   Reply With Quote
Old 01-10-2015, 04:51 PM   #10
nortonfb
Drives: 2007
It's been 0* F around here each morning for a week.
Never a problem. Nothing with grease on it want's to work easily until it's
warmed up a bit.
Norton
Old 01-10-2015, 08:13 PM   #11
Yarisgirl1964
Drives: 2008 Yaris
warmed up a bit.
Norton
Wouldn't the engine light come on if there was a problem? I'm assuming it's just the cold. it runs fine after I warm it up.
Old 01-11-2015, 05:24 PM   #12
john21031
Drives: '10 Fit Sport MT and 2012 Fit
Use synthetic oil in the winter in 5w30 or thinner viscosity. The mineral oil can become too viscous when cold and not circulate or lubricate parts when just first started. It's terrible for the engine. Start with the basics.
john21031 is offline   Reply With Quote
Old 01-11-2015, 06:32 PM   #13
Viscosity should be the same (within spec) mineral or synthetic.
Old 01-12-2015, 10:30 AM   #14
True, like you said "within spec". I you're in an area that drops temps below what the "5w" is rated in synthetic tends to flow better at those out of range temps. That's essentially one of the sole purposes in running synthetic (grade IV not V). There is no doubt it has made the cold starts easier and smoother for me.
That being said, I have never heard a grinding noise in any car at any low temps regardles of oil. I would think it's something other than a shearing noise. Unless a gallery port is plugged an oil isn't getting there at all?
