Old 01-09-2015, 03:14 PM   #1
RETRO
Drives: 2008 Yaris Hatchback
Loss of MPG
I know these post come up often. I have a 2008 Yaris HB. I bought used 5 years ago with 24k miles. For 4 years I got 41-42 mpg in the summer and 39-40 mpg in the wither. Dec 2013 I noticed my mpg dropping.I lost about 2 mpg per tank.I have changed the plugs that made no difference. Today I am getting 33 mpg in the winter and 36 in the summer. I use the same station for years. I now am using another station and getting the same about 32-33 mpg.My driving is the same and nothing has changed on it. really confused on this car runs smooth just not sure what else to do.Suggestions Thanks.
RETRO is offline   Reply With Quote
Old 01-09-2015, 03:48 PM   #2
It's possible the AFR sensor is getting lazy. My '05 was getting the same way except i was getting random codes regarding running too lean and misfires. So I had a friend perform an active test on the cars fuel enrichment while monitoring the O2 reading and it indicated the sensor was not reading properly anymore. Replaced it and gained 100-150km per tank.
Might be something to concider.
It might also be that the fuel companies are adding more and more ethanol content to the fuel mix.
Old 01-09-2015, 03:51 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
This was posted in the wrong section of the forum, moved it to the correct one.
Old 01-26-2015, 04:31 PM   #4
RETRO
I've clean the MAF,throttle body. Ran seafoam through the brake booster and tank. Still no improvement.Thats my thinking higher % of ethanol in gas.
Old 01-26-2015, 04:33 PM   #5
Have you monitored the A/F sensor to make certain it's reading correctly?
Old 01-26-2015, 08:31 PM   #6
RETRO
I have not and not sure how to.
Old 01-26-2015, 10:27 PM   #7
You'll need a wiring diagram. You might be able to back probe the OBD connector inside the car with a volt meter to take the reading while you drive the car.
CTScott might be able to help.
Old 02-05-2015, 06:50 PM   #8
RETRO
it is reading 0.2 volts at idle? what is the correct voltage?
Another Loss of MPG Thread... WeiseGuy Fuel Economy Forum 7 04-25-2014 02:33 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 12:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
