Old 01-12-2015, 02:18 PM   #1
duendeverde
Drives: Yaris 2010 Manual
New Clutch Installation
I bought from Amazon a Luk Clutch Kit for my yaris 2010 Sedan (Pressure Plate, Clutch and TOB)
Installed it last saturday and the feeling was great since my last clutch was slipping. I don't know why but today I heard a squeal sound. I thought that it was the serpentine belt but i wasn't
I noticed that If I apply small pressure to the clutch pedal the squeal disappears and also I saw the clutch fork moving (wobbling to be exact)
The mechanic told me that everything was installed correctly. What can it be, the TOB, the clutch fork or the clutch kit
To be more exact, the following youtube link shows a car with the exact problem as mine
https://www.youtube.com/watch?v=wIbE6aPncbk
duendeverde is offline   Reply With Quote
Old 01-12-2015, 05:55 PM   #2
colj00
DIYer
Drives: yaris 1.5 MT
my car has been doing that since it rolled off the dealers lot. i was told by the mechanic that it was the pressure plate springs.
colj00 is offline   Reply With Quote
Old 01-12-2015, 06:26 PM   #3
duendeverde
Mmmm ok, bad luck for me, the clutch kit was brand new. I was thinking of buying an Aisin Clutch Kit just in case if a clutch part came damage
Old 01-19-2015, 12:34 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I am leaning toward the release bearing. I have had 4 of them now through my different clutch setups. It is a dead giveaway for sure if you barely depress the clutch pedal and the sound goes away. Needs proper lubrication during installation otherwise it will dry out and eventually cause premature wear on the assembly.
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
Clutch & Flywheel Installation help Needed. victorddr DIY / Maintenance / Service 9 01-10-2011 12:09 PM
