Old 01-14-2015, 03:06 PM   #1
svdrh
Drives: 2007 Yaris 4 Dr HB LE Auto
How to adjust clock in radio
Hi everybody ! I got a 07 Yaris LE I like to know how can I adjust the clock located in radio, because the owner's manual doesn't mention it. Thanks in advance.
svdrh is offline   Reply With Quote
Old 01-14-2015, 04:00 PM   #2
Kar98
Drives: 2011 Scion tC
Post a pic of it please.
Old 01-14-2015, 05:15 PM   #3
Top right of the page gives us a Search option on this forum. Here's a link on how to change the time.
http://www.yarisworld.com/forums/sho...=setting+clock
Old 01-14-2015, 05:34 PM   #4
svdrh
This is the radio/CD player I have.
Old 01-14-2015, 11:22 PM   #5
Going to make a guess here but hold the number 3 SET button down until the number blinks (most likely starting the hour) then tab until the desired hour is reached, then hit the SET button which will most likely start the blinking of the minutes. And repeat functions as you did for the hour. Again, it's a complete guess but sounds plausible, who knows?
Old 01-15-2015, 09:59 AM   #6
I would say hold 3. And press 1 or 2 to adjust the hour and minutes.
I don't understand the Yaris coming with this radio in Canada. Stupid dealer installed radios...
Old 01-15-2015, 10:22 AM   #7
Kar98
I knew it couldn't have been this setup, because that would have been too obvious even to the most inexperienced driver.
Old 01-15-2015, 02:14 PM   #8
My friend also has the CD player above with the clock.
Old 01-15-2015, 03:02 PM   #9
Kar98
Must be a Canadian thing.
Mine looked originally like this:
Until I changed it to this:
Old 01-15-2015, 03:28 PM   #10
jcboy
Drives: Sedan 07
Too bad you had to change the panel, when you couldve just bought spacers or the kenwood 200mm radio. matter of fact folks here usually buy those panel off of the lower trims, as the higher ones have integrated radio. (integrated radio is pointless to me, cause there are no features that differ them from aftermarket such as door indicators, "good morning" voice greetings, etc.)
Unfortunately the ones buying the lower trims enjoy the simplicity of things, and are not selling them off. Even i had to buy an aftermarket radio panel as the OEM ones were more expensive and was only available at the stealership, much less didnt include the spacers.
Old 01-15-2015, 03:43 PM   #11
Kar98
I used the spacer panels initially, but that looked too ghetto for my taste.
Old 01-23-2015, 03:57 AM   #12
El Kapitan
Senior Veteran
Drives: 2007 5 door hatchback
hi KAR98. do you like call of duty by any chance? :)
OP and future readers of this thread, for setting the clock, it's done by pressing and holding the AM/FM button at the top right (you can see that it says "clock" just above the button). while holding that button down, press the "1" key for setting hour and the "2" key for minute.
El Kapitan is offline   Reply With Quote
Old 01-23-2015, 02:54 PM   #13
jcboy
Drives: Sedan 07
Oh yeah, it does have a different fit with the spacers. with the 180mm kit, the unit sits flush.
Old 02-19-2015, 05:08 PM   #14
svdrh
Hi ! I found a solution it's so simple just press "AM-FM" button for 2 sec. it will disable.
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Custron T1062TYT Review (Long) mr.steevo In Car Entertainment + Electronics (audio / video / alarm) 1 11-24-2011 02:13 PM
ATL, I want to trade my Upgraded built in radio... matthewallanstill Southeast 2 03-28-2009 06:29 PM
Mounting a CB radio somewhere Sodium Duck Cosmetic Modifications (Exterior/Interior) 1 03-06-2009 01:50 AM
I want to trade my Upgraded built in radio... matthewallanstill Items for Sale by private party 0 09-03-2007 09:50 AM
