Old 01-24-2015, 09:34 AM   #1
basharalezze
Drives: yaris sedan 2008
Red face Troublesome problem
can any help me my car yaris sedan 2008 A/T 4 speed my problem is the fourth speed not working RPM arrived to 4 and 120 km and the gear dont shifting to the fourth worker of maintenance told me that the reason is speed sensor turbine as shows in Screening device
basharalezze is offline   Reply With Quote
Old 01-24-2015, 12:21 PM   #2
The mechanic could be correct. If the diagnostic tester is indicating an error code for the turbine speed sensor, that would make sense.
The turbine speed sensor is located on top of the transmission, next to the gear driven speed sensor. If the two sensor's data does not agree, then the computer will report an error and will have issues with shifting.
Old 01-24-2015, 03:14 PM   #3
basharalezze
thank you very . but what is the solution .. should replace speed sensor turbine
Old 01-24-2015, 06:59 PM   #4
Yes. If that does not fix it, then the transmission is internally slipping and that will require a rebuild or replacement of the transmission.
problem with co-worker yaris, need opinion on what it could be. Adriaan DIY / Maintenance / Service 5 10-20-2014 06:39 AM
Yaris TR 1.3 '08 AC problem Eeman DIY / Maintenance / Service 5 07-03-2014 04:59 PM
Audio off whilst using ipod nano problem via USB Becci In Car Entertainment + Electronics (audio / video / alarm) 4 05-07-2014 08:20 AM
Problem with electronic door lock new-yaris-owner In Car Entertainment + Electronics (audio / video / alarm) 7 08-05-2012 05:12 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
