Old 01-28-2015, 12:58 PM   #1
driverofchuckles
driverofchuckles's Avatar
Drives: 2008 Yaris. Manual everything
Belts belts and more belts
I have a 2008 HB 5spd Manual Yaris with 117k miles on it. My belt has started squeaking. I bought my Chuckles with 27k. I do not know if the belt (pretty sure I'm hearing the serpentine or what I call the timing belt) was ever replaced.
My question, and it's one that I'm kind of embarrassed to ask, is what is the best brand of belt to buy? Are some better than others?
Many thanks in advance!
driverofchuckles is offline   Reply With Quote
Old 01-28-2015, 01:19 PM   #2
I would say just about any belt will do, just stay away from Dayco.
I have a goodyear gatorback on my Yaris and i have no complaints.
Old 01-28-2015, 02:11 PM   #3
driverofchuckles
Awesome. Thank you!
Old 01-28-2015, 03:30 PM   #4
Stop calling it that ;)
Old 01-28-2015, 06:08 PM   #5
Kar98
Drives: 2011 Scion tC
It's not a timing belt. Your car has a timing chain. The belt you're looking for is called a serpentine belt.
I just bought this one:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Bit spendy, but seems to work in my manual '07 hatchback with A/C and el. P/S.
Old 01-28-2015, 09:54 PM   #6
CoryM
Drives: 2009 5-door, 5-speed
As mentioned, Dayco are terrible. Our customers typically get Napa (manufactured by Gates) or OE belts. Both have a good track record. I'm not a fan of Gatorbacks as they can cause a "whirring" noise on some vehicles, but are usually OK.
Do not over-tighten the belt or you will be doing a waterpump in the near future. Yaris pump bearings are a bit weak to that.
Cheers.
Old 02-01-2015, 08:36 PM   #7
mimelio
Drives: NONE
This is right from Gates
http://www.gates.com/~/media/Files/G...lt%20Noise.pdf
mimelio is offline   Reply With Quote
Old 02-01-2015, 08:58 PM   #8
Originally Posted by mimelio View Post
The "B" measurement actually matches the Toyota spec for tensioning the belt. I find that the best way to tension the belt is hot. Run the car for 10 minutes or so to heat up and soften the belt and then kill it and tighten the belt.
Old 03-08-2015, 12:19 PM   #9
driverofchuckles
Thank you all! Going to be getting a new serpentine belt today. I will never again call it a drive belt or a timing belt. It's finally starting the slow process of warming up here in North Central Illinois so I can start back at the modding of my Chuckles.
Old 03-08-2015, 02:42 PM   #10
CB900F2
Drives: 08 Sedan
Great find!
CB900F2 is offline   Reply With Quote
Old 03-08-2015, 06:32 PM   #11
andulong
andulong's Avatar
Drives: 2008 Hatch Red
I thought you were referring to "Chuckles"
andulong is offline   Reply With Quote
Old 03-09-2015, 12:28 PM   #12
driverofchuckles
Well I bought the Gates K040465 belt. And now the lower bolt on the Alternator is being soaked in AeroKroil. I fear I may have rounded the head too much but damn is that thing on there tight! I deal with aircraft hardware and those torque values are insane but this is beyond torqued! Any tips on getting that damn bolt loose?
