Old 02-02-2015, 03:29 PM   #1
ndzzb
Drives: 2011 toyota yaris
How to make a duplicate transponder key?
Hi guys,
I lost my only key for 2011 yaris. There is an engine immobilizer on it. So, I have to make a transponder key. The quote from dealer ship is around $400, I think it costs too much. Is there any other way to make it?
Thank you guys!
ndzzb is offline   Reply With Quote
Old 02-02-2015, 03:33 PM   #2
You have to have one of the other original "master" keys to add a new one and the Toyota Techstream tool is required to program the new key into the ECU.
Old 02-02-2015, 05:13 PM   #3
ndzzb
Hi Scott, unfortunately, I don't have any original master keys. I bought the second hand car, only come with one key, but I lost it.
Old 02-02-2015, 07:15 PM   #4
That will be a problem. I believe that without one of the original master keys the transponder key ECU has to be replaced with a new one in order to register a new key with no existing keys.
Old 02-02-2015, 08:44 PM   #5
ndzzb
Do you mean I have to replace a new ECU? How much will it cost?Could I buy a transponder key from ebay and let the dealship cut and program it?
Old 02-02-2015, 09:18 PM   #6
It's not the key that they are charging you $400 for. It is the Transponder key ECU (89780-52061) which is about $300 plus the replacement key (89785-60160), which is abut $35.
Old 02-02-2015, 09:46 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
No need for master key to program new keys but u need to reprogram ECU by obtaining a 6 digit code directly from Toyota this will wipe the ECU old security and reprogram with new with and new cut keys don't know why they are charging u so much tho it's about a 15 min procedure with tech stream online with Toyota plus cost of keys and remote.
Old 02-02-2015, 09:55 PM   #8
Are you sure about that? According to the service manual, with no master keys in possession the transponder key ECU has to be replaced to add new keys. I know that when you buy a new Toyota you get a little metal tag with the keys that you are told "not to lose". My understanding is that code is just for cutting the physical key - It has nothing to do with resetting the transponder.
Old 02-02-2015, 10:40 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yes I have done one on a sienna ..same problem person lost all but one key no masters .
In order to do this I had to log with Toyota and its full of security as in they need my name , blood lol etc after that I get the code that basically resets the whole security and at this time u can load blank keys as ECU is reloaded but like I said only Toyota employe can do this and one has to be verified .
But this is completely different procedure from just adding keys with that u need master for simple add on of lost key with out special security protocol .
Old 02-02-2015, 10:42 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
But yes the other code u mention is for key cut . All other is to reprogram the security.
Old 02-02-2015, 11:07 PM   #11
That makes sense. So, it's definitely not a DIY. I wonder if the OP's dealer is charging the $400 for that service or if they are doing the service manual route?
Old 02-02-2015, 11:14 PM   #12
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
By the sounds of it they are doing the manual route and charging for something that just need programming with new security .
Old 02-03-2015, 05:50 AM   #13
ndzzb
Hi wolfman,
Thanks for your useful information. How much will it cost generally? Dealership told me they have to order a new key from toyota for $165, together will other costs, almost $400. but the key is much expensive than ebay. could I buy a new key myself?
Old 02-03-2015, 05:56 AM   #14
ndzzb
They said to order a new key for $165, and look for code/cut/program/, totally about $400. I think it cost too much.
Old 02-03-2015, 10:45 AM   #15
ndzzb
Hi Scott,
Where did you find the part number? Does it require VIN to find the correct part number for my car??
Deactivating the lost key. vicky DIY / Maintenance / Service 6 11-14-2014 12:19 PM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
Replacement key / keyless entry mcduck DIY / Maintenance / Service 4 08-30-2010 06:52 PM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
